Question about Haier Air Conditioner
My Haier wondow air conditioner seems to be blowing cold air but it is not cooling the bedroom. It worked great a few nights ago and made the room really cold but now its not cooling.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
How do you make your old wall air conditioners blow refridgerated air again?
I'm pretty sure those work just like the AC unit in a home or car/truck/SUV. If they are low on Freon the cooling unit (compressor) will not engage...so the air that it IS blowing is just recirculated air (the air from the room). Try looking for a HVAC company in your air...see if they can give you a (free) estimate. If it's not the Freon, then it's possible it could be the compressor is bad.
Jason
Oct 04, 2014 | Heating & Cooling
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Haier hwr06xc7 window unit a/c: fan works, compressor turns on, but just blows room temp air (which sucks when it's 114 deg here). can this model be charged? is there something else i can check first...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Haier HWR06XC7 Air Conditioner
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
10,200 BTU a/c blows air but not cool air
They can freeze up if the outside air is too cool. It needs to be over 65 degrees outside and inside. Another possibility is if the unit is a little low on refrigerant. They will run too cold if slightly under charged or if the condensor is very dirty and the heat can not be exhuasted.
Aug 27, 2009 | Heating & Cooling
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
Window unit air conditioner kicks in only when its really hot out
I would consider replacing the t'stat if it does not seem to cycle at the desired temps. Also, the outside air allows fresh air to be introduced into the conditioned space but it will also effect, to a degree, the units ability to cool the conditioned space. Once you get the unit running, try it with the baffle on and closed and see which one you like. Remember, the outside air has and add humidity and can make it seem hotter than it really is in the room.
May 21, 2009 | Whirlpool Electronic Window Air...
MY HAIER A/C IS NOT GETTING COLD
I have a fairly new Haier Air Condition that I bought last year, it has been working good up until last night. I keep this one in my bedroom and put it on every night since the summer. Last night I woke up very warm, the temp reading was 75 the AC did nothing but blow out just air. I threw away the booklet on it because I've had no problem up until now. Does anyone know how I can make it cold again. HELP!!!!
Jun 22, 2008 | Heating & Cooling
Heating & Cooling Logo
123 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
