Question about Polaroid TLA-04011C 40 in. LCD TV
MY Polaroid TLA-04641C power light blinks back and forth red then blue. I was watching TV and heard a pop, then the TV went out about 10 seconds later. I looked at the caps and nothing appears blown. Please help!!
  • 362 Answers
SOURCE: Remote code for dish network
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment. Let me know if this helps and please rate the solution.   lone99star
Posted on Jan 11, 2009
  • 718 Answers
SOURCE: Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Posted on Feb 23, 2009
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
dsacco86
  • 1077 Answers
SOURCE: POLAROID TLA-04011C does not turn on
The most likely the TV has a power supply related problem or it maybe just a blown fuse inside the TV.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by some chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
SOURCE: tla-04641c won't turn on
my tla-04641c stoped taking commands the day after using it with my laptop and was stuck on so i unplugged it and now it wont turn on when i plug it in the red light comes on and i hear the relay click button nothing happens when i push the on button. any suggestions? i pulled the power board and nothing "looked blown"
Posted on Feb 09, 2010
Why does my flat screen tv turn on and off by it self and the only way to stop it is unplug power cord?
This is an indication that they capacitors in the power supply are going bad.
Jan 20, 2015 | Televison & Video
Need an owner manual for TLA D4641C
Thought that was going to be easy but Polaroid no longer have the manuals available for download on their site. Typical.
Anyway, here's a direct link to download your user manual (free):
http://www.hdtvreview.com/pdf/polaroid-tla-04641c-manual.pdf
Click the link, PDF will open in a new window. From there you can view, save and print. Please note your model number is actually TLA-04641C.
Please rate my solution if you find this helpful. Thanks.
Oct 16, 2010 | Polaroid Televison & Video
Tla-04641c won't turn on
Aug 23, 2009 | Televison & Video
POLAROID TLA 04641C AFTER VGA PLUG TV WON'T WORK
i am having the same problem.. did u ever got it fixed?
May 10, 2009 | Panasonic Televison & Video
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Polaroid TLA-04011C LCD TV remote codes
I have the TLA-04011c and have yet to find a code. Out of curiosity, have yall? thanks
Dec 21, 2007 | Samsung SyncMaster 17 in. LCD Television
Polaroid TLA-04011C 40 in. LCD TV Logo
79 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
