Question about Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher
Leaves fine grit inside glasses, cups, etc. Dirtier dishes than before washing.
    Problem Solver:
  • 8 Answers
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The "fine grit" is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
Posted on Aug 12, 2011
I use siemens dishwasherand recently noticed some grit like substance left on my dishes etc after every wash
There should be a screen under the spray bar. Make sure that is clean. So "grit" is not recirculated in the wash cycle. Is "grit" showing up in your house water elsewhere? Check with clear water glass. Also consider testing with a competitive wash compound to see if there is any difference. A sample or from your friends.
Apr 14, 2015 | Siemens Dishwashers
We have a kenmore elite 66516593200 that has been leaving grid in some galsses and cup. Any ideas why or how to fix this?
the grit is from the detergent , maybe your using too much for your cycle , ck your owners book for proper amount , in older diswashers the spray arms stop moving and jam up this does same thing and dishes arnt being cleaned , i use the masking tape test , place one piece of tape to end point of basket and stickit dont wrap it to wire basket (bottom) , close up door and run on wash for 15-30 seconds if tapes are not loose then arms arnt moving and need attention or replacemnt
Feb 20, 2015 | Kenmore Dishwashers
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
My kelvinator dishwasher kd14ss leaves stains in my glasses cups and small bowls in the upper rack after each wash. Never used to do it before - turned up the rinse and check the salt, but after each wash...
It sounds like you need to check the filters and clean them. It’s usually pretty simple to do but makes the dishwasher run like new. I think that it might be obstructed somewhere preventing it from being able to fully rinse the dishes. Is it draining all the water after the cycle has finished?
Feb 03, 2018 | Kelvinator Dishwashers
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
May 20, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher Grit?
Hi julie
Chances are you are using to much detergent and the water is not hot enough. cut back on the detergent and run your hot water tap at the sink first and that should fix it.
brent
Sep 29, 2008 | Dishwashers
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Bosch Evolution 300 SHE43M05UC Stainless Steel Built-in Dishwasher Logo
354 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
