Question about Fishman Prefix Plus-T Preamp - narrow format
I have a Fishman Prefix Plus-T in a Carvin Cobalt Guitar. To replace the battery do I have to remove/loosen the two screws holding the sides of the battery cover or is the battery supposed to slide down without removing the screws???
  • Fishman Master
  • 5,603 Answers
The little plastic catch above the word "prefix" should release the battery carrier.
Posted on May 29, 2011
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
Hello, I bought a second hand Martin J1 that has a fishman rare earth single coil pickup fitted. The problem is, when its plugged into the amp ( AER 60w) it makes a cracking noise every so often when
You have several options:
1. Do nothing and live with the occasional problem.
2. Check your guitar cable and the battery connections for loose or intermittent connections/noise. Try to see if it's the amp responsible for the noise....ie, Is it caused by vibrations, or maybe static....especially in winter when it's dry. Your home power may have noise on the line, so borrow or rent a power conditioner which filters out noise. If that fails, go to 3.
3. Bite the bullet and pay a competent guitar tech/luthier to repair it. Most of these issues are due to loose/faulty connections. Should be less than an hour. Hey....It's a Martin.
3a. Pay a guitar tech to loosen the end pin connector so you can see if you can repair it yourself.
Dec 25, 2017 | Fishman Rare Earth Single Coil Acoustic...
How to tune Fishman Prefix Premium blend
If it is the standard ISYS try
http://www.fishman.com/files/isys_preamp_system_user_guide.pdf
Jun 30, 2012 | Washburn NEW PRO WASHBURN ACOUSTIC GUITAR...
Fishman Prefix Plus preamp on my acoustic guitar picks up the unwound strings well but the wound strings are barely audible
You could try boosting the bass and reducing the highs on the EQ setting, however there MAY be a probllem with the pickup, not the preamp.
Apr 05, 2011 | Fishman Prefix Plus-T Preamp - narrow...
I bought a Martin DC16GTE last year in Germany, brand new. (Music Store, Cologne) My Fishman prefix premium blend has a tuner build in. It tunes properly, but once activated, I can't turn it off by...
Most devices using a button to turn them on off SEEM to require HOLDING the button down for a bit (few seconds) to make sure you really want to turn the device off...
Dec 16, 2010 | Fishman Prefix Premium Blend Preamp -...
My Fishman Prefix plus is not working through an amplifier and the tuner will not stay lit
Check the battery in the preamp. Also adjust the eq to see if you might be clipping the frequency you are generating.
ALSO do not overdrive a tuner... they get confused and won't register.
Sep 01, 2009 | Fishman Music
Unit inoperative, one LED blip on battery install only.
Its possible that if you changed strings the saddle might have changed position in its slot. It has to sit uniformly on top of the piezo element in order to work properly. Try testing the pickup(piezo element) first before suspecting the preamp.
May 18, 2009 | Fishman Music
Fishman Prefix Plus-T Preamp - narrow format Logo
239 people viewed this question
Top Fishman Music Experts
Michial Gueffroy
Don Hart
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
