Unfortunatly while cleaning my LCD Monitor of my pc.. i dropped few drops of water and some how water just want inside,, now.. i have some black spots on my monitor though it works fine but still those black spots are not reducing.. any sugessions..
  • 32,281 Answers
Water and electronics do not mix.
Turn off your monitot and let it dry out for several days and then check to see if the monitor still works properly.
If not then you need a new monitor.
Posted on May 28, 2011
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me a procedure how can I clean my ViewSonic LCD Monitor screen.
To clean the monitor first turn it off then use something like a microfiber cloth or something that is not abrasive to clean the surface. Don't press down excessively this can cause damage to the monitor. If that does'nt get all the fingerprints and such off a solution of distilled water with a little
white vinegar will do fine just use it lightly and don't drown the monitor. Make sure to use just enough solution to lightly dampen the monitor and not so much as to run down the monitor and
risk getting inside where the circuits are.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Horizontal lines in the middle of the screen .....the rest is black
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the badparts, replace any that look like the pictues and your monitor shouldwork fine. The capacitors do need to be installed with the correct +and - connections, note the stripe on the old one and insert the newone the same way. You may be able to get the repalcement capacitors atyour local Radio Shack, if not there are several sites and the internetyou can order from. If you don't want to try the repair yourself weoffer a repair service for $35 plus shipping. I hope this helps, if soplease rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | Sony SDM-S73/B Monitor
Black screen on inside and outside has not been dropped may have water damage from water on my hands
i know the water sticker is still white because you didnt get the actual sticker wet... in order to get the sticker to turn red... the sticker has to be wet...!
May 29, 2009 | Motorola Mobility RAZR V3
There is a 4 inch wide back vertical strup down the diplay screen
It is probably be a faulty LCD crystal, or a bad internal connection where the electronics meet the LCD. I would think it could happen if the monitor is jarred or dropped, I guess it could occur also if the monitor was brought in from the cold weather and condensation occurred inside?
Unless you have access to a trained LCD technician, your only option is return the monitor for exchange or repair, or buy a new one.
Apr 03, 2008 | Westinghouse LCM-19v1 Monitor
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Feb 15, 2008 | Microsoft HannsG HU171D 17" LCD Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
