Question about Science Tech Toys
I own the Star Galaxy Pinball machine, made by Science Tech. It needs a new mechanism for kicking the ball into the ball "alley"...so that the plunger can launch the ball. Seems the spring is broken. We need a new piece with a new spring so that we can use our machine. Please help!
    Brigadier General:
  • 3,301 Answers
Contact these guys they have everything http://www.pinballreplay.com/?a=m
Posted on May 28, 2011
Tip
Flipping pinball flippers like a pro
Growing up my dad was a pinball machine collector, so we always had machines in the house and at a young age playing pinball was one of my favorite pass times. After spending many long hours playing and flipping those little flippers like a manic I realized that there was an art to using the flippers.
When it seems that the ball was going to go straight down the center of the playfield I would use both flippers to try and stop the ball from draining, but it was an action that never worked. I discovered that using only one flipper helped me to catch the ball more often. And this also helped me to discover that you don't need to flip the flippers as often as you might think.
The game of pinball is all about timing and aim, there was one time that I discovered that if I raised the flipper at just the right moment I could bring the ball to a dead stop. This gives you the ability to better control the ball or even take a short break so long as you don't take your finger off that button. You will learn after the first few times playing pinball that it is not a game of random chance that the ball hits places on the playfield and win points but that there is an element of aim involved. With practice you learn the playfield well and the power that you need to hit the ball with to hit the targets. You will find that using a certain part of the flipper will cause the ball to go exactly where you need it to.
Pinball is a very fast paced game, in some instances the ball can be moving at speeds of 20mph! With this in mind when you successfully hit the ball you should immediately let the flipper fall. Holding the flippers up when you don't need them leaves a gaping hole in the center of the playfield and makes it harder to hit the ball if it comes down fast.
With time and practice you too can master the art of being a pinball wiz and amaze your friends with your unbelievable high scores.
on Oct 13, 2013 | Video Game Consoles & Games
I need a manual for a Halex Galaxy Mission pinball machine. Does anyone out there have one in a pdf format that they could send me or share here?
Manuals for many pinball machines can be found at www.ipdb.org. Those for Gottlieb machines are copyright protected and must be purchased. I don't recognize the name of the machine that you quoted. Who is the manufacturer and please re-check the title name.
Dec 13, 2016 | Video Game Consoles & Games
How do i fix my pinball machine it wont start when i push the start button a message on the keeps coming up saying pinball missing.
Make sure there is the proper number of balls in the trough. If so remove them and go to the test switches in the diagnostics menu. Test the trough switches one at a time.
Jul 14, 2014 | Video Game Consoles & Games
All balls shot out
I need to know what machine are you working on? Different era machines have different answers.
Feb 08, 2014 | Bally/Midway/Williams Video Game Consoles...
Machine can't find pinballs
If the game can't find all the balls on start-up it will hunt by kicking all the coils. If you look at the ball trough under the deck you should be able to see all 4 balls. If any are missing then they are stuck somewhere on the playfield. I they are all in there then use the buttons on the front rood to access the switch matrix display and check the switches. Most of the time you will find a ball or balls stuck somewhere on the deck behind a broken rubber or in a hole where the coil wire may have broken off. Don't worry about the settings in service mode. If you read the instructions on the display, you can't screw it up. Worst case you can always do a reset to factory.
Dec 30, 2013 | Stern Pinball AC/DC Pro Pinball Machine
Pinball machine won't start game, says looking for pinball and won't start game
This means the game does not find the balls in the machine. First look all over the play field and see if a ball is caught someplace. If so, remove the glass and get it out so it will drain. If you cannot find it, see how many balls are in the ball return trough and if it the correct number. If it is the right number, then one of the switched is probably going bad in the trough. Without the name of the game, I cannot tell you if it is a micro switch or an opto switch in the trough.
Dec 30, 2013 | Video Game Consoles & Games
What is the standard size of a pinball ball?
the standard size is 1 1/16" there are some machines that use smaller balls you can check online for what size you should use for your particular machine.
Oct 03, 2013 | Video Game Consoles & Games
I have the DK pinball science, the way things work. It says it can't run because it was made for Windows 95 and We have Windows xp..how can we get it to work? Heather
Ok, I know how to fix this.
Find the exe file that starts the program, and right click it.
click on properties.
Then click the tab for compatibility
there will be a check box that you will need to check to run in compatibility mode, and a drop menu that offers different versions of windows to run under.
select windows 95 , then click apply.
close the property box, and reboot
when the computer starts back up, the program should now run, as it has now been told what to do for compatibility.
Jan 29, 2011 | Dk Multimedia The New Way Things Work And...
I bought a Star Galaxy Professional Pinball machine from Toys R Us about 2yrs. ago. The company is called Science Tech a trademark of Bowen Hill Ltd. Within about 3-4 mths after my purchase the ball quit...
Hey, figured mine out, you have to take off the front right plastic molding, and the piece that creates the track, then inside there is the scoop Rednax was talking about. Mine wasn't loose, it was busted clean off at the plastic mount, so since that plastic shaft was hollow, I bought a metal dowel that fit tightly in the shaft and some loctite plastic glue and stuck it all back together and hoped for the best, since I don't know how to weld plastic. thats been about 2 weeks ago, and I do daycare and its still together so I'm calling it a successful fix. Those 2 parts don't come out easily though, they are a major pain in the rear to get out, but you just gotta yank and pull and pry to get them out. Its a much bigger hassle to get them all back in place!
Dec 30, 2010 | Video Game Consoles & Games
Toys Logo
246 people viewed this question
Top Science Tech Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Science Tech Toy Expert? Answer questions, earn points and help others
