Question about HTC Touch Cellular Phone
Switched POWER OFF in error. How do you switch it back on again?
  • 122 Answers
If the battery is drained or you have changed config:
connectthe phone to your computer using a mini USB cable, pull the phone's battery out and inserted it back in.
good luck
rene
pls tumbs up if this worked :)
Posted on May 28, 2011
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
Samsung LCD TV backlight switched off
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 24, 2017 | Samsung LE-46A566 46 in. LCD TV
We switched all the power in the house for half hour . when switched back on the control panel lights on the samsung fridge/freezer will not come back on
1 Switch the power off again and wait for some time. Switch -on the fridge
2 Check the power plug. Ensure it is properly fixed & not loose
3 May be the bulb is fused
Nov 17, 2009 | Samsung Refrigerators
My oven wont work
Get out your User Manual and follow the initial setup instruction
The machine is waiting to be told what to do
You will need to turn off the power to the cooker and when you switch it back on again you have a limited amount of time to put in the settings so write them down on a piece of paper before you start
Jun 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Can not register Archos for WIFI connection
Switched unit on and held tv button until repair options showed. Selected repair disc then switched off when task completed. Switched back on and selected systems and again selected reset settings and switched off. Then this time I removed the battery and pressed the reset button. Switched back on re-entering all the required data.Everything now appears to be functioning normally.
Thank you for your offer of assistance,will keep your site on file incase of future problems.
Aug 29, 2008 | Archos 705 WiFi Portable Multimedia Player
Frozen flashing multiple errors
pull ur ink cartride from cas and clean it and put it again
May 01, 2008 | HP PSC 1510 All-In-One InkJet Printer
Service req E527 error
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
Error c00f0401
I have faced the same problem. Eventually I switched off the power, unplugged the cable connecting the printer to the computer, plugged the cable back into the computer and switched on the power again. Much to my surprise the printer performed a self test and worked again. I do keep seeing this error code, but the above "procedure" seems to work for me. Goodluck!
Feb 27, 2008 | HP OfficeJet V40xi InkJet Printer
Printer going offline
How long is you usb cable? don't use to much long cable. better to use only 1 meter. because too long may cause error to your printer to pc.
Dec 05, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HTC Touch Cellular Phone Logo
18 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
