Question about Whirlpool Duet GHW9150P Front Load Washer
I get an f06 and e01 error and the door is locked. How can I reset the washer?
  • Whirlpool Master
  • 17,970 Answers
F6 code is an issue with the motor drive tachometer.
Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, one at time, and reinstall. If this does not work, you likely have a faulty control.
E1 means that the thermistor is open and needs to be replaced. The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
For replacement parts - head on over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and enter in your full model number for a full parts listing.
Hope helps.
Posted on May 28, 2011
My whirlpool duet washer has error codes, F06, E01 and int. how can I reset the washer?
The Electrically Erasable Programmable Read-Only Memory (EEPROM) on the main electronic control board is corrupted. Unplug the washer for 5 minutes, restore power and see if the code clears. If not, the replace the main electronic control board.
Oct 14, 2016 | Whirlpool Washing Machines
Maytag Maxima front load washer "master reset"?
To start, E01 and F06 means that your main central control board (CCU) and the motor control board (MCU) are not communicating with one another properly. The motor control board is located under the tub mounted to the floor of the washer. The CCU is mounted under the top panel of the washer and is the part with about 100 wires going into it. You'll want to remove the top panel and the lower front panel to check the wire connections and make sure they are all secure. If everything looks good, then you just have to somewhat guess which control board you want to replace first, either the MCU or the CCU. The problem is that there is no way to test and determine which part is faulty so it's just a guessing game. That's what makes this one of the worst errors to get. I generally replace the CCU first as that is the part that shakes around a lot more during spin and it's the first place that the power goes from the power cord if there is any fluctuation in power, so it makes since that this part fails more than the mcu.
There is no Master reset. The only thing you can do is unplug for 1 minute then plug back in.
Oct 28, 2015 | Washing Machines
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
I have a whirlpool duet steam and reads codes F06 E 02 and replaced the electric controller and now reads F06 E01
OK your almost there. The switch or Latch that locks the door is faulty or bad. It is either that or probably not connected to the right terminal. New control board!!! That was expensive! Good luck!
Jan 16, 2014 | Washing Machines
Error code F06 and E01
Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
F06 and F14 error codes
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Aug 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
6,419 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
