Question about ASUS VH236H 23 inch Monitor
I want to remove the base from the monitor to enable a wall mount.
2 Suggested Answers
  • 902 Answers
SOURCE: How to remove the stand/base for wall mounting.
there usually are two or 4 little screws on the bottom of the base or on the side where it connects to hte monitor some actually have a press button release on the back let me know if this helps!
Posted on Mar 17, 2011
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How do I remove the base from the TV so it can be wall mounted without leaving the stand attachment attached to the TV
depends on what TV you have. Most TV models i've dealt with, you need to remove the whole back of the TV and take the base out. Some smaller LCD monitor bases like Dells are attached only by a latch. Some bases are held together by 4 screws where the VESA mount would go.
Mar 22, 2011 | Computers & Internet
How do you take the base stand off of an envision 22in lcd tv? I want to mount it to the wall?
There is a screw on the part of the base where it connects to the monitor back, it is located on the pivoting arm, remove or take loose this screw and lift the base by holding the side opposite the screw. the base should lift off with at very most just a bit of wiggling. You can now use the wall mounting screw holes located under the corners of the sticker on the rear of the monitor, they are usually covered with a perforated area.
Jan 16, 2011 | Envision H22W 22" Monitor
How do I remove the base neck from the monitor? I
theres a scre that is making the base stick to the monitor, take it out and slide out the base, or check the user manual for that
Feb 15, 2010 | LG W1934S-BN 19" Monitor
Type and size of screws to attach wall mount to viewsoni 17" lcd
Hi there!
Please refer to Page 7 of your VA1703w user manual for help on mounting this monitor, if you do not have the manual available, you can get it online here: http://www.viewsonic.com/assets/022/7368.pdf
From what I can tell, you may be re-using the screws that you remove during the listed procedure.
Feb 17, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
ASUS VH236H 23 inch Monitor Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
