My Honeywell thermostat 32002418-001 reads "FR-return". What does this mean? Do to correct?
5 Suggested Answers
  • 57 Answers
SOURCE: My Honeywell programmable thermostat reads
I think you need to charge freon gas to your a/c unit. Air should be coming out cold from your a/c unit once the compressor starts running. Always check if the compressor runs when you start the unit.
Posted on Sep 09, 2011
SOURCE: I have a Honeywell CT2800 Thermostat and a message
it's just running your "return home" program, so it says "return". the FR above it is just meaning "Friday". They line up in a way that makes it look like the two words are together but they aren't, the week line is just right above the program line.
Posted on Dec 12, 2009
  • 108 Answers
SOURCE: Thermostat is reading FR Return what does this
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Posted on Apr 03, 2010
heatman101
  • 43501 Answers
SOURCE: changed honeywell T8400C 1024 to
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Posted on Jun 12, 2011
Honeywell TH8110U1003, No heat reading, only two dashed lines, please help asap!
Sounds like the tstat communicates with a wireless remote sensor on the heating unit. The dashes usually mean there is something blocking/interupting the signal. Maybe another wireless device signal crosses its path.
Apr 24, 2017 | Honeywell Heating & Cooling
I have a honeywell programable thremostat, flashing "hold" at 63 degrees in the heat mode. What does this mean?
it means that you are in the hold mode. push run program and it will do the program. hold is used when you want to over ride the program,uplate,weekend,leaving town for a week. you can place it at say 63 or 75 what ever you want and then return to the program.
Feb 02, 2011 | Honeywell Programmable Thermostat Heater
Thermostat is reading FR Return what does this mean? It is a honeywell CT 3200.
Apr 03, 2010 | Honeywell CT3200 5-2 Day Electronic...
What does FR Return mean when thermostat says this?
it means that it is friday and your "return home" program is running. there isn't actually a "FR Return" alert, it just lines up that way because the day of the week line sits directly above the program line.
Dec 11, 2009 | Honeywell Electronic Programmable...
I have a Honeywell CT2800 Thermostat and a message FR Return came on
Jul 17, 2009 | Honeywell Electronic Programmable...
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
771 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
