I have a problem with my Dell E20 10H monitor it always goes in power sav mode I just want to disable it how do you?
  • hiboss2 May 29, 2011
    that dosn't help me it os not the couter it is the monitor I don't have a dell computer
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
Posted on May 28, 2011
Dell ST2310 goes blank
Change the settings to "always on" (both of the monitor and the computer).
Dec 08, 2013 | Dell ST2310 23 inch Monitor
Dell S2309W Monitor will not power on.
Sch will be really hard to come by since Dell does not really make the monitor, most of them are made by SAMSUNG and BenQ.
Send me pictures if you want, may be I can help you identify the bad parts. budmrtn@aol.com
That symptom may mean the power supply goes into shutdown mode due to short circuits.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 11, 2010 | Dell S2309W Monitor
Can't get out of powersaver mode
It is not really in the power sav mode, more likely to have failed power supply/inverter board due to bad caps, bad solder joints, etc. You need to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Jun 07, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My monitor states its in power save mode.when i press any key,nothing seems to happen.
To bring the computer out of the power save mode press the "Windows" key once and release, wait one second, then press enter. The system should come out of power save mode. The Windows key is the key with the Microsoft Windows Symbol on it. Another solution would be to disable power management.
To disable power management, right click on the desktop, click on properties, screen saver, then Energy Savings Settings button.
Change all the settings to "Never", then click on "apply" and "ok". Power management has been disabled.
Apr 29, 2010 | Dell E173FP 17" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Monitor keeps hibernating, can't make it stop, pixel issue.
Hey,
I think this is more of a problem on your computer instead of the monitor, ofcourse you could try another monitor and see if the same happens. I suspect your computer goes into standby or hibernation on its own, and it does work fine if you reset the computer right?
if you go into power management again, disable or turn off hibernation completely, its on one of the pages.
Make sure its not set to standby, and also disable your screen saver.
Right click on desktop - properties - then screensaver. turn it to none.
Also you could look into the computer bios and make sure its not set to standby or hibernation from there. thats unlikely but you could check.
how to get into bios.. depends on the computer, right when you turn it on, on one of the corners of the screen you will get a message, press button to enter setup or bios. press that to enter bios when its presented.
look around the bios and poweroptions.
Let me know if you need anything else.
Thanks,
Ekse
Feb 25, 2009 | Dell Dimension 8400 PC Desktop
Power Save Mode Problem
under bios menu look for ACPI function and disable it. Should help same under device manager.
Nov 26, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell monitor power down mode with Geforce GFX card install
I think maybe some how the main graphics for your pc has possibly switched to onboard. Try getting into bios F2 or DEl on boot up and highlight Advanced ChipsetFeatures and press Enter. In here make sure your AGP card is set as the Primary graphics controller. When done press ESC and 'Y' to save settings, then re-boot pc. Hope this gets you running again.
Nov 10, 2006 | Dell (M1325) (64 MB) Graphic Card
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
