Question about Dryers
We have a KitchenAid Whiper Quiet Gas Dryer that gets hot, stays hot for a few minutes and then cools. We replaced the heating element and not sure what else to look at. Any thoughts?
  • 776 Answers
Make sure your exhaust vent is not clogged with lint. Also make sure the lint trap is clean. Good luck. -mark
Posted on May 28, 2011
Gas dryer throws reset after a few minutes
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Apr 07, 2015 | Dryers
Top of GE drier hot
When the dryer gets toward end of cycle, the timer will cycle off the heating element. (last 5 - 7 minutes.) This function takes place thru a resistor located near the timer switch, and parallel with the heating element. If this resistor fails, the heating element stays on during the cool down period. The resistor can be checked with a meter. If it doesn't ohm out at 4500 ohms, replace the resistor... Make sure power is off at the appliance when you check for resistance.
Jun 23, 2014 | GE DBXR463EDWW Electric Dryer
Dryer continues to heat when door is open
The model number you put up is for a gas dryer, but you said element, so I'm assuming it is actually electric.
If this is in fact an electric dryer, you most likely have a heating element that has shorted to the case. There is a small chance that something else in that circuit has shorted to ground but I doubt it.
If this actually is a gas dryer, please discontinue use immediately and get a licensed tech over there to look at it.
Good Luck
May 16, 2010 | KitchenAid KGYS850LT Gas Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
Clothes dryer
your heating element has been drooping and welded to the metal part of mount and has broken unplug the unit and replace the heating element be sure to have a knowledgeable person do. make sure to unplug the unit b4 repair is done
Sep 06, 2009 | Kenmore 62802 Electric Dryer
Dryer gets hot for the first few minutes only
first check your venting. if you have backed up lint then it will not heat as well. if it's not your venting i would check to see if your heating element is broken and shorted to the casing..some times it will still heat if the coils weld themselves to the casing...if the heating element looks good then i would turn to your electrical.
Jun 16, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heats up cools down in few minutes? Kenmore gas
we need to take a look at the heating system and exhaust,,where going to start with simplest ok..your filter is cleann...check exhaust from back of dryer leadind all way out house make sure that path is clear...next pull exaust off and run dryer,,if not good,,let me know ,,onthejob
Jan 10, 2009 | Dryers
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 15, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
