Question about Garden
I have a Craftsman model 917.273482 and the deck is riding on the left wheels when it is in the fully lifted position. What did I break in the suspension of the left side I can't see anything wrong.
I have the same mower and had that problem last year. There two lifting links (part #11 and #12 of page 45 of the owners manual) that pick up the deck when you move the lift handle. I found one of these links broken (at the place where it was bent to form the curve into the deck). Bought both a left and a right side, figuring the other will fail soon. It did, about a month later. Sears will ship the part promptly, and it is not expensive.
Posted on Mar 19, 2012
    Brigadier General:
  • 3,301 Answers
From the manual I just looked at,, the wheels attach to the deck on that model,, so some part is misaligned or bent,, here is the page showing the deck and wheels,, maybe it will help you http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273482/0247/1509200/P0308003/00010?blt=06&prst=0&shdMod=917273482 You can look up the entire lawn tractor at searsdirect ,, Hope that helps Please take a moment to rate my response Thanks Good Luck
Posted on May 28, 2011
My riding lawnmower not cutting even, craftsman 46"
first check that the blade or mandrel is not bent or damaged --and check the air pressure in tires on right side --lower deck towards ground on a level surface until left makes contact now adjust the level arms they are on either side of cutter till right side is level with left on some of the older decks can adjust the front deck wheels also
Aug 25, 2016 | Craftsman Garden
I have a sears craftsman rider..model #917.527643, I cannot lower the mower deck to the ground. Any suggestions on how I may fix this problem?
I could not look up by model number. You have the right number of digits, but the sears craftsman parts site would not recognize it. So I am guessing that you have a knob that the operator can reach under the steering wheel and lower and a little left. If you have one of these knobs, it is a deck lower limiter. It is easy to turn if the deck is fully up. If the deck is lowered to bottom and the deck does not go to bottom and you turn this knob you will feel significant resistance. This resistance is caused by the weight of the deck on the limiter. With the deck fully up, turn this knob to fully lower the limiter and then lower the deck. Should go to ground or just a hair higher.
If any questions, please send reply and I will get back to you.
If you found this really helpful, please rate 4 thumbs up.
Jul 14, 2011 | Garden
The belt that comes from the engine to mower deck keeps breaking. I've owned the mower for years and I have to buy atleast 12 belts per year. The problen is really bad now. A belt per cutting. I've...
I own a Craftsman rider, DTY 4000, 25 HP Kohler, 48" cut, 137 Hrs. It eats a belt about every mowing or two. Did all the stuff you did. Good luck from Sears. Had cousin who is owns a lawn & garden repair business look at it today. Says the prob. is this - The drive belt pulley (elec clutch) has too a narrow "V" and the angle of wear between it and the deck when the deck is in the lowered (mowing) position is too severe. If you notice with the deck in the fully raised position the pulleys line up perfectly. Then drop your deck and see how tightly bent the belt is downward and it makes sense as to why(my) belt would first roll over then break in a few minutes. The elec clutch pulley is sold as one unit PT No. 179334 $250.00, but I'm sure it would come with the same narrow V pulley. Waiting for word from my cousin. My last Sears Mower. Cannot even sell it in good faith.
Aug 07, 2010 | Craftsman 48" Cut Riding Lawn Mower Deck...
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Getting Rear Wheel Off A Sraes Craftsman Riding
pull off plastic axle cover in the center of the wheel, remove large e-clip seen on the end with small screwdriver and large washer. take care not to let it fly off somewhere. lift tractor with a jack, pull off wheel then note the location of the square shear pin and save it for reverse assembly
Apr 16, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 25 horse Craftsman. Link lift that raises the deck keep breaking
the deck is connected to the tractor in three spots. The link that breaks repeatedly does so because the opposing link is frozen up. Replace both links and you will be back in operation.
Aug 02, 2009 | Craftsman Garden
Lift links
I imagine the lift links to be a piece of steel with a couple holes in them. Ask a local welding service to make your lift links. Typically you will not find part numbers for a part so eazily reproduced.
Sep 24, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
