I have a Vulcan quasar wall furnace when the thermostat comes on the television will turn off for a few seconds. Thermostat has been replaced 6 months ago. the termostat makes a hissing noise when coming back on
22yooper
  • 828 Answers
SOURCE: Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
Posted on May 22, 2008
  • 143 Answers
SOURCE: I have a vulcan quasar
Perhaps the fan motor is bad. If not, you have an electrical problem.
Posted on Jul 24, 2008
pierre1811
  • 144 Answers
SOURCE: Carrier Weathermaker SX (model 58SX100)
There is a small tube that comes off the inducer for cracks or water. If there are cracks then the pressure switch that it is attached to may not be closing all of the time. Also sometimes you can get water in that tubing which will also cause the pressure switch to not close. If thats the case shorten the tube so there is no low droop in it where water can collect. Another thing that I would do is disconnect the tube at the indicer, take a straightened out paper clip or stiff wire and poke it in the nipple on the inducer to make sure it is clear too. Let me know if any of these work. There may be other things we can do.
Posted on Jan 19, 2009
farfield
  • 462 Answers
SOURCE: thermostat location on York Diamond 90 gas furnace
Augold, sometimes its best to set the thermostat where you "feel comfortable" . I.E. set it and leave it til you feel the need to be cooler or warmer.
A thermometer on a thermostat will not always be accurate and setting it will only get it within 2 to 5 degrees which is enough to "feel".
Now from the stand point of is it working properly????
Assume you feel comfortable and the heat stays on to keep you comfortable is their anything wrong with this? I assume this is the goal. Even if it says 90 (and you know its not 90) and your comfortable you could leave it alone and be OK. If this kind of thing is whats bothering you a new thermostat may not be much better, unless your ready to invest in one and accept it however it should be closer to the place youd set it. Id recommend an electronic type they are more accurate and level doesn't matter so much to these types.
If you want to set the temperature and are determined to go by a thermometer to "feel Comfortable" I recommend you buy an electronic thermometer and set it close by the thermostat. Make sure you have no lamps or other heat sources close to the thermostat area.
Remember the far end of a room or a chair by a window Especially with little or no curtains and on the prevailing out door wind will always feel colder and be colder than the area by the thermostat even if both are in the same room. If your too cold try running the thermostat up a few degrees. If too warm set it lower. The equipment doesn't care how cold or warm it is.You will not increase your utility bills to the national debt by being comfortable
If this helps please grade me accordingly and Good Luck.
Posted on Mar 03, 2009
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
Thermostat sometimes doesn't turn furnace on
Hello Kathy, The first thing that I would do is change the batteries in the thermostat. One or more may be weak and not turn on your furnace. I would put in Alkaline batteries. If that doesn't help, maybe a new thermostat is in order.
Feb 27, 2014 | Hunter 44550 Programmable Thermostat -...
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
I have a thermostat that periodically turns blank and heat stops working. To get it to work again I go to the attic, where the furnace unit is, and turn off the switch for the furnace at the wall, then...
try to replace your thermostat and conduct observation with your furnace if happen again after replacement of thermostat furnace also damage.
Feb 19, 2011 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Oct 05, 2009 | Heating & Cooling
Vulcan Quasar 40 air issue
Hi the problem you have is your heater is cutting out due to the over temp switch getting to hot the reason for this is that your fan is not working thus not enough air flow is getting through the heat exchanger to keep it cool
your heater is designed to not exceed a certain temprature so as not to become a fire risk
to solve your problem you will need to replace your fan
this will solves your problem
Jul 27, 2009 | Heating & Cooling
Dellllllllllluxe programmable thermostat chronotherm plus iv
Does your thermostat have batteries. What is the brand of furnace and model # . Does the furnace have a pilot light or is it electronic ignition. if you need heat you can take thermostat of wall and take wires that are labeled r and w and wire nut them together to see if furnace comes on. Make sure you turn breaker off to furnace first before you take thermostat off the wall. If furnace comes on after you turn power back on after you connect those two wires together then you will probally need new thermostat. If not you have a problem with your furnace. If you have any questions after you try this feel free to ask any more questions.
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Turns on and Turns off
Does the furnace burners light? You could have a bad thermostat or a flame sensor. To check if it is thermostat turn power off to furnace take thermostat off wall take wires marked r & w and connect them together then turn power back on. If furnace comes on and stays on then you need a new themostat if not it is the flame sensor inside furnace. Also check furnace filter
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Rheem Furnace sometimes takes a couple of ignition cycles before
Try cleaning the flame sensor. It is located right besides the last burner. Looks like a thick piece of wire. Take steel wool and gently remove the carbon that has built up. Should only take 4 or 5 strokes. Let me know how it goes after that. ken
Dec 23, 2008 | Heating & Cooling
Wall gas furnace
look inside the control panel of the heater. look for a 120 volt to 24 volt transformer.  There may be a fuse on the transformer secondary.  The thermostat switches a hot 24 volt wire so you won't find a common at the thermostat.
Nov 13, 2006 | Empire GWT-25 Wall Mounted Panel Heater
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
