Question about Sharp Aqous LC-26D5U Television
Sharp aquos LC-37HV4M,Wont power up,no screen Image. Power indicator lamp flashes red for 250ms and off for 1sec. cannot enter service mode either.thanks Jeff.
  • jeffbelsey May 30, 2011
    Thanks,I shall order the part and let you know what happens.
    Cheers Jeff,
  • 373 Answers
Power supply bad: part number RDENCA032WJZZ Do a search with the part number on Ebay or www.shopjimmy.com to see price and availablity. Be sure to match numbers off your board to the parts listed. A google search will bring up other suppliers.
Posted on May 28, 2011
  • TV Doctor
    TV Doctor May 29, 2011
    Please accept my solution
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp aquos LC70LE650U 5 short flashes 2 long, no display
Try unplugging the unit and hold the volume up and channel down buttons down and plug the unit in. Let go of the buttons and the unit should come on up the service mode. There will be a small k on the screen. With the remote press the channel up button . This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. Use channel down to highlight that line and the curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged .
Nov 20, 2014 | Sharp AQUOS LC-70LE650U 70" 1080p LED-LCD...
Is a flashing power light on a sharp model # LC-19SB24U tv a repairable problem? tv will not power up.
push vol-, input, and power, at same time. keep push until tv start. Then you will see k123 at your screen. Now push vol-, and chan- at same time. You will enter service mode. Look for "error no reset" change the value to 0.
Nov 17, 2009 | Sharp Televison & Video
Sharp LC 37HV4M Flashing red light on screen when attempt to switch on and the remote tuner box wont fire up even though the power is on?
hi,
your main board or powersupply is faulty
or
One problem involves the lamp cage being loose. The fix is easy. All you do is remove the lamp and put it back in, making sure everything is tight. I guess they had a problem at the factory, for a while, not tightening the lamp cage. After a certain number of heating cycles, the lamp quits making connection.
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp LCD TV LC-37GP1U flashing green power light
Unplug the unit for 1 minute, replug and try again. If it doesn't work the power supply is faulted and it needs professional service.
Sep 10, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sharp LC-32D43U
This unit probably has a bad power supply. It may also be shutting down because if this unit has recorded 5 lamp errors it goes into shut down. To eliminate lamp errors you can force the unit on in the service mode and look for lamp errors. To do this, you unplug the unit, and while depressing the volume up and channel down buttons at the same time, plug the unit in. Hold for 1 second and release. The unit will then power on and a small k should appear on the screen. If this does not happen then there is definately an internal failure that will require a sharp auth. service center. If the unit does come on with the k, use the remote and press the channel up button. This will produce a menu on the screen and you will note on line will indicate lamp errors. On the right side of that line will show the # of lamp errors. If it reads 0, lamp errors are not the issue, however if it reads 5, you can highlight that line by using the channel down button. Then use the curser right arrow to select the error and then again to reset them. Once the lamp errors have been reset to 0, unplug the unit and wait at least 25 seconds before plugging in. The unit will now power up normally and this may cure the problem for good. If this process corrects the problem and it occurs some time later or right away that will be an indication that either the unit has bad backlights or inverter has failed and will again require service.
Feb 07, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aqous LC-26D5U Television Logo
178 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
