Screen Display Issues:
Go to the BIOS. Once you power on the laptop immediately hold down the F2 key then BIOS will show up. Try to check in BIOS if the display has low illumination if yes then try connecting your laptop to an external monitor then toggle the display to the external monitor. If the display from the external monitor is fine then it means the LCD has issues and needs replacement. But before going into any LCD replacement try to update the BIOS version first.
DVD Issues:
Check first the DVD icon in My Computer window. If missing then kindly do this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318
Delete the upper and lower filters.
Uninstall the DVD device driver from device manager.
Restart the computer.
Check BIOS if ODD or DVD is present. If yes then F12 boot to DVD if failed replace DVD drive.
If the DVD not present in BIOS replace DVD.
Most often the display issue your having can be resolve by replacing the inverter. the dvd drive thats non working can be found on ebay at a resonable price. please stat the model llaptop so ii can further assist you in resolving these issues
