Question about HP Office Equipment & Supplies
The bottom of my letters are missing. HP 1610 all-in-one. Ran all tests in HP toolbox solution center.
    Guru:
  • 352 Answers
Hello.
Remove the cartridges and try this method below. it is possible you have a slight block in the heads and the method described will fix it.
http://www.fixya.com/support/r3986425-unblock_print_heads
I hope this helps Regards GM
Posted on May 28, 2011
How to check ink levels in a HP officejet J4580 printer
Checking ink levels
  1. open HP solution center on the computer desktop screen
  2. click on settings on the bottom
  3. click printer toolbox
  4. click the estimated ink levels tab
or
  1. on the printer control panel,push the wrench button
  2. press the right arrow to go to print report
  3. push OK
  4. select self test
  5. push OK
It will print a page with color bars signifying correct ink levels.If a color bar is blank it means it's empty or depleted and needs to be replaced
Jul 21, 2011 | HP OfficeJet J4580 All-In-One Laser...
Printer won't print in black -- changed the cartridges. Nothing comes out on the page when I try to print.
the inkjet nozzle or printhead may be clog.
you will need to run the clean inkjet tool atleast 5-10 times to clear the inkjet nozzle.
  1. Make sure there is plain white paper loaded in the input tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
    HP Solution Center opens in a separate window.
  3. Click Settings (c01495176.gif ).
  4. Under Print Settings , click Printer Toolbox . The printer Toolbox opens in a new window.
  5. Click the Device Services tab.
  6. Click Clean the Printheads .
  7. Follow the on-screen prompts until you are satisfied with the quality of the output, and then click Done . When the cleaning is complete, the product prints a test page. Figure 13: Example test pagec01496479.gif
  8. Recycle or discard the test page.
Mar 06, 2011 | HP Photosmart C6380 All-In-One InkJet...
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My printer prints a blank page what can I do to fix this?
Hi Good day!! Maybe your printer head needs to clean.
Cleaning the printhead
Use one of the following methods to run the printhead-cleaning tool
NOTE: The cleaning process might take several minutes to complete.
Method one: Clean the printhead from the HP All-in-One control panel
Follow these steps to run the printhead-cleaning tool from the product control panel.
1.Load letter, A4, or legal size, unused, plain, white paper into the main input tray.
2.On the product control panel, press the Setup button.
3.Press the Right Arrow button to select Tools , and then press OK .
4.Press the Right Arrow button to select Clean Printhead , and then press OK . The product cleans the printhead.
5.Press the Back button to return to the main screen.
Method two: Clean the printhead using HP Solution Center
Follow these steps to run the printhead-cleaning tool from HP Solution Center, which is a component of the software that shipped with your product.
1. Open HP Solution Center:
Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
2.Click Settings, and then click Printer Toolbox . The printer Toolbox opens.
3.Click the Services tab, and then click Clean Printhead .
4.Click Clean to begin the cleaning process, and then follow the on-screen instructions to complete the process. A test page prints after the cleaning process completes.
Oct 17, 2010 | HP Officejet 6500 Wireless All-in-One...
Hp psc 1610 all-in-one states "insert print cartridges" and they have been inserted
I had the same problem. I put the new cartridges in and then ran a test page.
That was all i need to do. Hope it works.
Jun 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
How do I clean the print heads? My black ink will
  1. Load unused, plain white letter or A4 sized paper into the tray.
    • Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center
HP Solution Center opens.
  1. Click Settings.
  2. Under Print Settings , click Printer Toolbox . The Printer Toolbox opens in a new window.
  3. Click the Device Services tab.
  4. Click Clean the Printhead .
  5. Follow the prompts on the screen, and then click Done .
May 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
Hp 2480 desk jet printer prints photos with a large white border at the bottom how do i fix this? - thanks - Andy
Cleaning cartridges
# Open HP Solution Center:
* Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
* Windows Vista: Click the Windows icon , click All Programs , click HP , and then click HP Solution Center .
# Click Settings
#In the Print Settings area, click Printer Toolbox . The printer Toolbox opens.
#On the Device Services tab, click Clean the Print Cartridge(s) ( ).
#Click Clean to begin the process.
Can check by cleaning the Roller inside - Problem usually come because of the dust on the roller
Happy new year
Jan 03, 2010 | HP Office Equipment & Supplies
My C5180 won't print. It sounds like it is printing but spits out a blank page
>try the steps on this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01449854&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1153481&lang=en
.also check if there is still ink on it try printing a self test page
Method one: Print the page from the control panel
  1. Load letter, A4, or legal, unused plain white paper into the main tray.
  2. Press the OK and Help buttons at the same time and then release them. The self-test diagnostic page prints.
Method two: Print the page from the computer
  2. Open HP Solution Center.
    • Windows Vista: Click the Windows icon (c01364735.gif ), click All Programs , point to HP , and then click HP Solution Center .
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click the Settings menu, point to Print Settings , and then click Printer Toolbox .
  4. Click the Services tab, and then click Print test page . The self-test diagnostic page prints.
Oct 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have the hp d1400 series...it wont print and its telling me i have an alignment problem..it all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
26 people viewed this question
Seeker5211
Seeker5211
