Question about Lincoln Electric Welding Tools
How many quarts of oil for 08 Lincoln mkz - Lincoln Electric Welding Tools
Murphybanton
  • 2004 Answers
SOURCE: 4.6 quarts of oil
This is not normal. Why not add more oil to ensure it gets to the second dot to avoid error reporting or engine knock.
Goos luck.
Rate this.
Posted on May 19, 2009
  • 18 Answers
SOURCE: Lincoln MKZ transmission whine.
Take back to where you had service and ask??? do at once
RB
Posted on Feb 20, 2010
Testimonial: "I plan to take it back to the Lincoln dealer that rotated the tires and changed the oil today. Thanks!"
  • 4793 Answers
SOURCE: What weight oil should I use in the engine of my
until someone comes up with a reason to use the most expensive 5/30 oil for a normal family car(as against a high performance sportscar)
i would recommend 10/40 semi and change oil/filter at 10k or annually(whichever first).5/30 would be good for ALASKA.
Posted on Sep 22, 2010
mastericpr08
  • 571 Answers
SOURCE: How do I reset the
Use this link: https://www.fleet.ford.com/maintenance/owners_manuals/results.asp
Posted on Oct 21, 2010
  • 111 Answers
SOURCE: looking for oil filter location on 2008 lincoln
YOU HAVE TO DROP PLASTIC SPLASH PAN ,UP FRONT BETWEEN THE LOWER CONTROL ARMS
Posted on Dec 21, 2010
I have a 08 3.5 mkz what is the wire decription for maff sensor .
  • 1 IAT (VIO/GRY)
  • 4 MAFRTN (VIO/BRN
  • 3 MAF (BLU/GRY)
  • 2 C SIG RTN (YEL/VIO)
  • 6 VPWR (VIO/GRY)
  • 5 PWR GND (BLK/GRN)
Sep 11, 2016 | 2008 Lincoln Mkz
What position is the 5 cylinder for a 3.5 V6 Lincoln MKX 08?
Standing in front of the vehicle with hood up looking towards back of vehicle cylinder 5 is the front center cylinder
1 2 3
O O O
O O O
4 5 6
Feb 27, 2015 | 2008 Lincoln Mkz
Black oil under my Lincoln mkz
transfer case is leaking. bad seal in transfer case. remove TC then replace seal. about 6 hours.
Apr 10, 2013 | 2007 Lincoln MKZ
How often do I change the oil in my new Lincoln MKz
I change mine every 3000 miles with conventional oil or every 5000 miles with synthetic
Jan 27, 2013 | 2007 Lincoln MKZ AWD
Transmission fluid capacity for 2008 Lincoln MKZ? in quarts
If you have the Asin Trans which most MKZ' woth V6 engine of that year such as my own MKZ take 7.4 quarts dry, probably about 5 if just removing the drain plug on the bottom. there is a drain plug which takes a large torx socket to remove, no filter because the valve body is located on the uppper side of the trans and not the bottom like normal transmisions. the fluid is a special fluid ,Motorcraft
XT-8-QAW Fuid.I would not rust any after market brand which says it is compatable. It can be bought at a ford dealer, or I even saw it for sale on Ebay. Hope this helps, you exact trans type can be found in your owners manual as well as on Fordowner.com if you make a profile and add your VIN of your vehicle to your garage. You can download manuals there and even make service appointments
Dec 30, 2010 | 2008 Lincoln Mkz
RB
Feb 20, 2010 | 2007 Lincoln MKZ
While slowing down, 08 Lincoln MKZ, car jolts slightly. Very tough to duplicate but it happens frequently
Absolutely take it to the Lincoln dealer. You have a longer warranty with a Lincoln, Lincoln loaners with appointment. Chances are Customer concerns are mounting and the dealer will check for Technical service bulletins.
It sounds like the downshift in the transmission is rough. These are computer controlled and they may be able to plug your car into a computer and reprogram it to the newest standard.
Sep 28, 2009 | 2008 Lincoln Mkz
Welding Tools Logo
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
joe_jochoa
Level 1 Expert
ray gallant
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
