LG WD 1023C washing Machine how do i turn off child lock
5 Suggested Answers
  • 8 Answers
SOURCE: My LG WD-1023C Automatic Front
it could be that your machine has been child locked, look in yor manual it will tell you how to fix it, this happened to me , hope this heps you good luck
Posted on Sep 11, 2008
  • 489 Answers
SOURCE: child lock is on my
Hold the child lock button again for 5 seconds to release the lock.
Good luck
Posted on Jun 15, 2011
SOURCE: LG Intellowasher (Model WD-1023C)
The door is jammed on my LG Intellowasher WD 1023C front loading washing machine. The cycle is finished, ubt the door won't open.
Posted on Jul 13, 2011
  • 16 Answers
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
Posted on Jul 14, 2011
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
LG Frontloader WD 1023c door not opening
If it won't unlock when powered down for a couple of minutes you will have to unplug the machine and then remove the top lid. you will then be able to access the rear of the door lock and pull the locking switch back to allow the door to be opened.
Dec 23, 2012 | Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Child lock is on my LG WD 1023C how do i tun it off
Good luck
May 28, 2011 | LG WM2277H Front Load Washer
Hi there My frontloader washing machine display
LG washing machines indicating error code CL may have the child lock activated. Try holding down the temperature and eco/rapid options together to turn off child lock.
Mar 08, 2011 | LG WD-1280FHD Front Load Washer
Machine displyas CL. Why
It means the Child Lock feature which locks the controls is turned on. Look for the two console buttons, usually adjacent, with the lock and child symbols between them like the one shown below. Press and hold those buttons simultaneously until the CL light turns off to unlock the controls.
Mar 02, 2011 | LG WD-1045FH Front Load Washer
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
LG "WM12336FD" washing machine is displaying ,CL,
I cannot find that model number in any of my LG data.
There is a button on the control panel that will say Child Lock. That button will have to pushed and held down until you hear the chime.
Apr 22, 2010 | LG WD-16115FD Front Load Washer
Child lock on - needs de-activating
hi..    here is the pdf user manual lin has been give . please download it..:
  1. Washing Machine. OWNER'S MANUAL. WD-3243RHD. WD-3245RHD. website : http://www.LGservice.com ..... To deactivate Child lock system, press and hold ...
    www.oasisappliance.com/products/lg/LGComboOwnersManual.pdf -
Sep 13, 2008 | Washing Machines
My LG WD-1023C Automatic Front Loader Washing Machine is displaying a CL error code and will not turn on.
Sep 11, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
