Question about Nexgrill 720-0234 (LP)
I am replaceing my burners on my 720-0108 and have no idea how to switch them out. I have purchased three stainless steel burners. I need a step by step instruction please.
  • 4 more comments
  • William Scot Ellis May 30, 2011
    That is not what I needed. I have the blown up diagram but it does not tell how to dismantle the grill to get at the old burners to replace them. Either tell me how to dismanatle and replace with the new burners in detail or refund me my money.
    The video shows a burner that is a straight burner not a U type burner that does not have a screw attachment at the back of the burner like the video shows. The burners only attachments are hide at the front of the grill. It looks like I would have to take the whole front off to get at it and that does not seem right. Please see the type of unit I am useing to get the right recommendations.
  • William Scot Ellis Jun 02, 2011
    As I have stated before this is a U shaped burner that has a pan above the drip pan that makes the access to the wingnuts at the top of the U. How do you get the pan out of the way so I can install the burners.
    The video that I was sent to is the wrong grill. I have U shaped burners that attach to the back with a wing nut. The problem is how do you get to the wing nut when there is a fixed drip plate up against the wing nuts. This is not the pull out drip plate/
    This is the wrong grill diagram. The grill I have has U shaped burners . Please read the other comments that I have sent.
  • William Scot Ellis Jun 03, 2011
    You keep giving me the wrong grill diagrams and the grill I have has U type burners that do not detach as the straight burners plus there is a grease directional plat in the way of getting to the wing nuts that I need to get off.
    Guru:
  • 868 Answers
Hi wmscotellis,
Isee that you are looking for a step by step manual for you Grill 720-0234.
See link Manual
I hope this helps you with your concern.
Thank you for choosing Fixya,
mvincentc
Posted on Jun 04, 2011
    President:
  • 1,654 Answers
  • Disconnect the gas supply from the grill, either by unscrewing the regulator from the valve on a propane tank, or shutting off the gas line at the cutoff valve, typically on the pipe connecting to the grill.
  • 2
    Raise the grill lid, remove the cooking grates and take out the lava rocks or ceramic bricks. Remove the grate over the old burner.
  • 3
    Loosen the burner by turning the locking nut counterclockwise with pliers underneath the grill in the center. Apply spray lubricant if necessary to free the lock nut from the bolt. Some of these models mount differently but the fact is you have to either remove the screws or bolts connecting them to the grill.
  • 4
    Pull up on the burner from inside the grill and tilt toward the front to remove the burner and tube assembly
  • 5
    Insert the two tubes on the new burner into the holes in the bottom of the grill and guide the burner into position, checking underneath the grill to fit the burner tubes into the venturi tubes attached to the back of the control panel. The grill tubes fit loosely inside the larger venturi tubes, which have small, round screens on the sides. The locking bolt underneath the new burner goes into the hole in the bottom of the grill.
  • 6
    Secure the locking nut to the bolt on the underside of the grill and tighten with the pliers.
  • 7
    Replace the grill grate over the burner, add lava rocks or ceramic briquettes and replace the cooking grates.
  • 8
    Reattach the gas regulator to the grill valve if using a propane tank, or switch on the gas supply at the shutoff valve.
  • Posted on Jun 03, 2011
    • 2 more comments
    • Dcramer531
      Dcramer531 Jun 03, 2011
      Some models also have burner shields that lay over the burners to catch grease and give off a smoke flavor, these simply lay in a groove above the burners so they can be removed and peplaced very easily.
    • Dcramer531
      I also did not see the other commenst and descriptions provided till right now, they don't show up tillo I answer your question. The wing nut is in the rear of the burners on these. I will look in the reference books for more specific info to give you.
    • Dcramer531
      When I look at this exploded vies all I see in the flame tamers that lay over the burners and a pull out tray that removes from the front to empty the grease and such. It may be screwd in from the front under the burner knobs. All these grills are different and every year they change models and the way they are buitlt. To put it simply there has to be either screws or bolts that hold any pans above the burners. Some models the screws are accessed from the out side of the grill.
    • Dcramer531
      These are not that hard no matter what shape the burners are, any of the ones I have worked on the burners all remove basically the same, you might have to twist yours up ward before sliding off the gas supply but they do come off. Any pan or diverter above the burners eiher has bolts or screws that hold them or yours is made with a permenant shelf and I have never seen one like that. When I look up the grill that you gave us the numbers on, there is no manual or information on that grill. I looked at the esploded view of on that came up on your grill and followed the instructions on assembly and went backwards and all it says is to install the covers over the burners and it also show a tray with a handle on it similar to the handle on the grill cover but smaller, over the burner control knobs.
      like I said all these are made different depending on what store you bought it from, they usually are made to the stores specks
    • 159 Answers
    Here you go hope this helps
    http://www.nexgrill.net/pdf/720-0140.pdf
    Posted on Jun 02, 2011
    • 10,865 Answers
    Hi wms..... here is a link to a video that shows exactly how to do this step by step. enjoy!
    http://www.nexgrill.net/info.htm once you go to this link click on INFO and then on the video on the right hand side entitled "Main Burner Replacement".
    Joe
    • 927 Answers
    Let me first say that if this information doesn't help you, do not accept the answer and you won't have to pay for my assistance.
    Secondly, I don't have that grill, but I removed and replaced burners on two different grills in the past few days.
    In most cases the burners run from front to back. Look in back to see if the burners go through the back sheet metal. The burners on my newest grill are attached to the back with 2 screws with nuts and washers on each. One does not have to disassemble anything to remove/replace these burners. Simply remove screws/nuts/washers, pull the burner out the back, install the new burner align around gas orifice and reinstall the screws, noting any alignment arrows or instructions such as UP.
    On my other grill, the grates, heat distribution covers, any briquets must be removed to see the retaining screws. The grill was so rusted that I couldn't even replace these burners.
    Before dismantling anything, open the doors below, remove any drip trays that come out easily and try to see what you are trying to get to in order to remove the old burners.
    Looking at the mounting arrangement on the new burners is also helpful.
    I hope this helps, let me know hou you do.
    Gary
    Posted on May 30, 2011
    • 683 Answers
    Check the nexgrill web at http://www.nexgrill.net, you can find manuals there with unit's exploded view.
    Posted on May 28, 2011
    • Angel Joseph Jr.
      Angel Joseph Jr. May 30, 2011
      If you visithttp://www.nexgrill.net/info.htm, You will find on the right side of the screen the Trouble Shooting Video Show that includes the Main Burner Replacement. Just click it to download video.
    After installoing a surface igniter why will one burner not ignite
    There might be many reasons. Wiring, spark module or spark switch. Here is video which can give You an Idea on Whats might be wrong. Thanks.
    Aug 07, 2014 | KitchenAid KGCK366VSS - 5 Burners...
    How do I change the burners on a Nexgrill Model 720-0108? Thanks for any info for less than handy woman!
    That same model number has several different burners. One is a straight burner (three each); a couple are loop types and several have a flat surface with gas outlets.
    Part Number
    Description
    Shopping
    Cart
    10361
    Stainless Steel
    Tube Burner
    10361.jpgThis stainless steel tube burner is a replacement burner for numerous gas grills produced by Nexgrill, some of which are sold under the Charmglow brand name. This burner is 16 & 13/16 inches long. Please use our Nexgrill drop down model list, together with the illustration and sizes, to select the correct burner for your grill. Most of these grills use three to five burners. If you wish to benefit from quantity pricing on the 10361 burner, see the order entries below for three-pak and five-pak quantities.
    This is the easy one - Just pick up the flutted end and slide out from the gas line. No screws or bolts
    $12.79 each
    Quantity:
    Jun 05, 2011 | Grilling
    Need to replace stainless steal buners. 17" long
    You have to remove the front panel to remove the old burners and install the new ones.
    Mar 20, 2011 | Ducane 30400040 Stainless Steel Grill
    I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
    That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
    Jun 11, 2017 | Viking Grilling
    How do I open the top of a Maytag MER5875RAS Stainless Steel Electric Kitchen Range. I have one burner that doesn't work properly and want to "ohm" out the burner elements.
    The following link explains how to access a surface burner on an electric range and replace (if required):
    http://www.fixya.com/support/r3692628-surface_burner_replacement_electric
    Replacement parts (if reqiuired) can be purchased at any of the following websites:
    searspartrsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
    If you have any questions about this repair, please post back and let me know. I hope this helps you.
    May 16, 2010 | Maytag MER5875RAS Stainless Steel Electric...
    What do you do when the ignition on a gas range keeps acting like it needs to light a burner when the burner is on? Sometimes we'll have three burners or all four burners going and the ignition just...
    Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
    Nov 23, 2009 | Viking VCSF036SS 36" Professional Free...
    Cannot light new burners
    I just replaced my burners and I also cleaned the starters. Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.
    Jun 02, 2009 | Ducane 30400040 Stainless Steel Grill
    GE Adora Griddle Top replacement
    part number for the griddle is WB31K10140
    partstore.com has it for $87.95 hope it helps
    Dec 23, 2008 | GE 30" Self-Cleaning Freestanding Gas...
    THE STYAINLESS STEEL COOKTOP
    I NEED TO REPLACE MY STAINLESS STEEL 5 BURNER WITH GRIDDLE COOKTOP ON MY 36 I TAPPAN RANNGE BUT DONT KNOW WHERE TO FIND ONE. I CANT SEEM TO FIND THE SRIAL NUMBER/MODEL NUMBER ON THE STOVE. HELP! DAN WILLIAMS
    Jun 16, 2008 | Tappan MGF500PBW Gas Kitchen Range
    Nexgrill 720-0234 (LP) Logo
    517 people viewed this question
    Top Nexgrill Grilling Experts
    80stech
    Gary Kenady
    Gary Kenady
    Michael Vincent Cruz
    Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
