Question about Canon Office Equipment & Supplies
What kind of ink should i use why if i insert a bond paper its going and its nothing happen?
  • 83 Answers
Hello rona check ur ink mybe its empty... or have pending printing try to cancel it and print again...
Posted on May 28, 2011
I don't have an idea where to put the bond paper on brother printer. i am confused weather on a tray or at the back of the printer// pls i need help..
normally you put it front. might as well check for any indication like bond paper mark with an arrow telling you how to insert the bond paper.
or
check the manual and look for the instructions on how to insert the bond paper.
Jul 03, 2011 | Computers & Internet
Ink does not stick to page on m2727 when printing cardstock. We have tried using different paper settings.
Are you using original HP toners or 3rd party (refills)? We have had issues with some 3rd party toners not bonding properly on heavier media. How heavy a cardstock are you trying to print on? If it is heavier than the highest rated paper for this printer then it may not bond at all, regardless of toner used. The heaviest paper that HP rates for this printer is 43 lb/bond. A lot of cardstock starts at around 65 lb/bond.
Jun 15, 2011 | HP Laserjet M2727nf Multifunction Printer
I have Hp Desk Jet 5652 printer. Black and color there are still ink left. Only blue and yellow prints on paper. I raced several times a cleaning program but nothing happens. Is there in printter some kind...
Hi
May be your late to refilled it and the ink dry
when that problem happened to me I put the ink in hot water
if the ink refill that's don't matter
try that and if that don't help you change the ink
Apr 25, 2011 | HP DeskJet 5652 InkJet Printer
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
Feb 22, 2010 | Minolta magicolor 2400W Laser Printer
Wasting alot of paper printing out on Hp Designjet 500
Step 1
Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
Step 2
Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
Step 3
If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
Step 4
Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
Step 5
If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
Step 6
If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
Step 7
Try changing the toner or ink cartridge.
Step 8
If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Nov 19, 2009 | HP PRINTER,DESIGNJET 500 42'' InkJet
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Won't align because it says that the "paper is too narrow".
On the right side of the carriage at the bottom is where the media sensor is. If you dampen a q-tip with water and wipe the underside of that sensor you will see ink come off onto the q-tip. That sensor is on the right side of the ink carrier and the light shines down onto the paper. The lens gets covered with ink and needs cleaning...
Jun 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have brought a replacement cartridge (black) for the Epson D92 stylus printer I folowed the usuel steps and sucsesfully printed 4 or 5 b&w pages now the printer does not seem to except the cartridge...
This may or may not work on your model
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
The Protection Counter referred to above prevents you from printing once the printed pages counter reaches a predetermined threshold.
If this doesn't work, let me know.
Regards,
Worldvet
Nov 11, 2008 | Office Equipment & Supplies
Blank screen during playback
your camcorder video head is dirty, use a brand new tape and playback for around 5 minutes or more, this will serve as your video head cleaner. you may try at least five times doing this: insert, play, eject,play, eject again. your camcorder has a built in videohead cleaner and activates only during insert, play or rec, and eject mode. If the problem is still there, manual videohead cleaning is needed, use clean bond paper and lighter fluid, damp the bond paper (Size about 1" by 3") with fluid and rub with care the videohead (not the bond paper!The vhead should be the one turning not the paper)by slowly turning the videohead against the paper. Be careful cause this is dangerous that you might brake the videohead permanently. apply only a slight force to the head.
Aug 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Paper jam message
1 Step One Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.) 2 Step Two Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible." 3 Step Three If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer. 4 Step Four Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper. 5 Step Five Try changing the ink cartridge. 6 Step Six If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Aug 27, 2007 | Dell 924 All-in-One InkJet Printer
23 people viewed this question
old marine
old marine
