Question about Amphion Mediaworks T-365 System
Lost remote fo amw 365 - can't get all surround sound speakers to work. Want to adjust manually withou remote and no luck
    Brigadier General:
  • 3,301 Answers
Call these guys and tell them what you have
1-800-REMOTES
(1-800-736-6837)
Posted on May 28, 2011
3 Suggested Answers
SOURCE: Where can I get a replacement remote control for a
I dont no wher is replacement your remote but you need a new remote Contact Kapil Electronics. ph-no-033-2253-7406.
Posted on Aug 25, 2009
SOURCE: How do you manually eject a DVD from a AMW T-365
You can remove the cabinet by removing 4 screws. Then pick up white circular plastic ring over the DVD and carefully ease the DVD out backwards.
Posted on Jun 04, 2010
Which universal remote will operate every aspect of my dav-ex150 sony home theater system? Would like to adjust the settings for the speakers. As of now I only have sound coming from sub woofer and front...
On your receiver you should have a 'surround mode' and a 'display mode' which activate the surround speakers. If you are not in a 'mode' just the 'left', 'right' and 'sub' speakers will work. As for a remote, many of the newer receivers can be controlled via 'App' through a phone or tablet.
I hope this helps
Jun 09, 2014 | Audio Players & Recorders
How do I adjust the surround sound without the remote?
I was able to find a manual for this receiver at this URL...
http://www.devicemanuals.com/productsupport/Denon_AVR-800_manual.html
Its a free download. I did a search through the file and there is a way to do this. Apparently, the remote for the AVR800 doesn't allow you to adjust the rear speakers anyway, so no problem about no remote.
Hope this helps...post an update if it does or not and I'll keep searching for an answer if not.
Feb 01, 2013 | Audio Players & Recorders
Cannot increase sound on TV using remote or manually
HERE'S THE ANSWER TO YOUR PROBLEM:
There are times that TV sound problems does not require you to call for a technician. Some TV sound problems are just easy to repair, and you can just do it yourself. Try to do this one:
1. Press the "Mute" button on the remote control or press the "Volume Up" button. The most common cause of no sound is accidental use of the television's "Mute" function.
2. Make sure the speaker source switch on the back of the television is switched to "Int" if you are using the television's speakers and "Ext" if using surround sound. If not set properly, you will not hear the television sound.
3. Access the television's equalizer by pressing the "Menu" button, selecting "Sound" and then "Equalizer." A list of sound options will appear on the screen. Use the up and down arrow buttons to select the option you want to adjust, and the right and left arrow buttons to make adjustments to the option. You should use this method of adjusting the sound settings if the audio output is in some way unusual.
4. Check the surround sound speaker wires and make sure they are secured to the audio jacks on the back of the television. In addition, ensure that the surround sound speakers are powered on.
If it does not work still. Contact your service provider.
Thanks... I hope this helps...
Jul 23, 2011 | Protron PLTV-32 Television
Where can I get a replacement remote control for a model number P8A5 surround sound system by AMW ''Amphion Media works''
Aug 25, 2009 | Audio Players & Recorders
I lost my remote to my Durabrand surround sound system. Where do i get another?
You can visit this site to order a replacement remote...
http://www.remotes.com/?gclid=CIGHiPOGq5gCFQMnGgodeBwtnw
I hope that helps
Thank you
Computerrep
Jan 25, 2009 | Durabrand 5.1 Surround Sound Computer...
Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Jan 23, 2009 | Philips HTS3544/37 Theater System
I lost my remot control and the manual
you can purchase this items thru phone calling jvc directly 1-800-252-5722 or on there website jvc.com. the remote will cost $27.01 and the manual $6.18 plus tax and shipping. you can pay with visa or mastercard. if you hear sound thru 2 speakers there's a surround button on remote that can get the rest of speakers working. or you will need to check speaker connection and set unit to right surround setting by pressing surround button.
Nov 17, 2008 | JVC THD-50 System
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Amphion Mediaworks T-365 System Logo
140 people viewed this question
Top Amphion Mediaworks Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Amphion Mediaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
