I have a Goodman WMC24-1A Wall Mount Air Conditioner. The red light on the far right is flashing. What is the light? What does it mean when it is flashing? And is there somewhere I can get a manual to look this up in the future? I just washed the outside unit and it started acting up. I have noticed increasing leakage from the unit.
  • 11,800 Answers
That is the status light and it indicates a controller failure - most likely the water you used to wash the external unit has got in and shorted a control relay. To fix that the unit will have to be opened and the electronics board tested to find the faulty part - a job only a pro can do it, you will have to call one.
The water that leaks from the unit is a normal part of the operating cycle - the water vapor from the atmosphere condenses on the cold coils of the evaporator and it drips . The quantity of dripping water is directly proportional with the humidity in the atmosphere so more leaking water during the rainy periods of the autumn is totally normal.
Posted on May 28, 2011
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Goodman wall unit air conditioner WMC 24-1A has a orange raindrop light displaying and is leaking wayer from the right side???
You need to make sure the condensate pump is working. Check the voltage and the float in the sump.
Jul 21, 2014 | Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Does the goodman air conditioner have a reset button? running but not cooling
Is the fan in the outside unit rrunning? If not, then it is either the contactor relay or the capacitor.
http://www.hvacpartsoutlet.com/GoodmanRoundDualRunCapacitor.aspx so far this is the cheapest place I have found for genuine Goodman parts.
Jul 16, 2011 | Goodman CKL36AR36 Air Conditioner
My goodman air unit wont turn on but has power to the relay and can be manually overridden at the relay but doesnt sound like the air handler comes on. I changed the batteries in the thermostat and even...
Check the transformer. There could be a chance that the transformer is out. If you mean you can manually turn on the unit by pushing in the contactor switch in then theres your problem The thermostat engages the low voltage side of the transformer sending 24 volts to the contactor switch engaging the system if this transformer is out it will not engage the contactor to turn on the system.. Also on the air handler at the door on the bottom of the airhandler there should be a small circle of clear plastic by looking inside of this circle you should see a green led . If you see a red led it will be flashing count the flashes as they are emmited and once you see the pattern they have then remove the bottom door of the airhandler and on the bnack of this door is a code that corresponds with the flashes i.e. 3 red flashes, pause, three red flashes. The code will tell you what is occuring within the system. However, If your system is not a newer model it may not have the leds as I have described. If that is the case the first part of this solution may correct the problem.
Good Luck on your repair
Dave
Aug 31, 2009 | Goodman CLT24AER24 Air Conditioner
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Jun 10, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
562 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
