Question about MSI Microstar GT680R-008US 15.6" Notebook PC - Black
No indicator lights for numlock, capslock, and scroll lock? (msi gt680r-us)
  • 52 Answers
All those indicator lights are set in a particular circuit.that must be damaged. so taki it to the customer service center....
Posted on May 28, 2011
What would be the probable cause of a sony vaio fs830/w of starting up & the 3 green leds on top stayed lit
You were FORMATTING it? Meaning... you were erasing the operating system? If that's the case, then... you have no operating system and the computer cannot boot up because it has no operating system to boot into.
Jul 30, 2014 | Sony VAIO VGN-FS830/W Notebook
Tip
Make Your Keyboard Lights Do DISCO
Friends this is just a small trick that will just make your dance means its lights will go like disco lights of a midnight club.your keyboards light goes in rhythmic way it too cool u try and make fun .These codes when executed makes your Caps, Num, Scroll lock keys flash..
very cool...i hav tried it...
1.This piece of code makes ur keyboard a live disco...
Set wshShell =wscript.CreateObject("WScript.Shell")
do
wscript.sleep 100
wshshell.sendkeys "{CAPSLOCK}"
wshshell.sendkeys "{NUMLOCK}"
wshshell.sendkeys "{SCROLLLOCK}"
loop
2.This one makes it looks like a chain of light....
do
wscript.sleep 200
wscript.sleep 100
wscript.sleep 50
loop
Instrcuctions:
*paste any of the two above codes in notepad
*Save as "AnyFileName".vbs
*Run the file
*to stop, launch task manager and then under "Processes" end wscript.exe
I hope u would like it...
on Dec 23, 2009 | Computers & Internet
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 08, 2012 | Computers & Internet
Capslock10 times blink with both indiator num/scroll lock are off
It certainly does indicate motherboard issue, sub out the ram memory one at a time and test, if no change! the laptop needs to be checked out for motherboard problems.
Apr 11, 2012 | Dell Latitude D600 Intel Pentium M 1.3GHz...
Hi, How I shall get to know whether Keyboard's capslock numlock or scrolllock hey is on or off on Logitech Cordless MK250??? I am getting big trouble in entering different capital or small character's...
if the corresponding Numlock, Capslock, Scroll lock light are ON, then it says that the corresponding functions are activated...
For example if the Numlock light is ON, then you will be able to use your number pad...
if caps lock light is ON, then you will be able to use the Capital letters...
Dec 10, 2010 | Logitech Wireless Access Duo Optical...
The Fn key is working opposite of how it is supposed to. i need to depress it in order to type normally
Try Fn+NumLock
This had me stumped for a little while too because I'm so used to num lock referring to changing the function of the number pad, not enabling the inline number pad. That and the lack of indicator lights for numlock/capslock status.
Mar 09, 2010 | Adesso WKB-3000UB Keyboard Trackball
And light on keyboard are working but system not starting up why
remove external peripherals. remove battery. use ac adapter alone. when u turn on laptop check the lock leds. what is the status of the lock leds (numlock) (capslock) (scroll lock)
Dec 02, 2009 | Dell XPS M1210 Notebook
Laptop wont turn on, Capslock just blinks
what's the status of the other link lights? the numlock an scroll lock? are they bliking or steady on? try to eseat the memory modules
Oct 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
'why the ligth for the uppercase letter function flashing for 9 times and the dell d600 don t start
basically the problem that you are having is a no P.O.S.T (power on self test ) issue or to make it clear the computer is having some problems turning on. Now, how is the capslock light related to the problem? For dell portables it uses Numlock, capslock and scroll lock key as diagnostic indicators as well. based on your discription, the off-flashing-off combination means that there is something wrong with the main board on your computer. and the badnews is the part costs a lot. you'd probably end up paying $400.00 for the parts and repair.
Hope this helps.
thanks.
Nov 18, 2007 | Dell Latitude D600 Notebook
MSI Microstar GT680R-008US 15.6" Notebook PC - Black Logo
171 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
