Question about LG WM2277H Front Load Washer
Child lock is on my LG WD 1023C how do i tun it off
  • 489 Answers
Hold the child lock button again for 5 seconds to release the lock.
Good luck
Posted on Jun 15, 2011
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
I've got a LG Intellowasher WD-1023C and it spins real slowly or not at all and there is a glow from the bottom, it also stops with 9 minutes left on the 30 minute wash
a glow does not sound good. any error codes. glowing sounds like a hot/shorted wire, maybe the heating element. i think i would unplug and call for professional service.
Oct 25, 2016 | LG Washing Machines
How do I remove child lock from lg washer WD 10165FU
Push child lock or key symbol button for three seconds
Feb 24, 2015 | LG Washing Machines
LG Frontloader WD 1023c door not opening
If it won't unlock when powered down for a couple of minutes you will have to unplug the machine and then remove the top lid. you will then be able to access the rear of the door lock and pull the locking switch back to allow the door to be opened.
Dec 23, 2012 | Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
The cl lock is on and won't oppen
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 12, 2010 | LG WD-14124RD Front Load Washer / Dryer
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Aug 23, 2010 | LG Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
My LG WD-1023C Automatic Front Loader Washing Machine is displaying a CL error code and will not turn on.
it could be that your machine has been child locked, look in yor manual it will tell you how to fix it, this happened to me , hope this heps you good luck
Sep 11, 2008 | Washing Machines
LG WM2277H Front Load Washer Logo
67 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
