Question about HP LaserJet 2300 Printer
When I do duplex printing in my hp 2300dn, the top and bottom margins in the even and odd numbered pages differ by 1 centimeter. How to get equal margins in all pages?
  • HP Master
  • 1,915 Answers
If would first make sure that you have the proper paper sizes set on on the printer and in your driver. I have not had this particular experince with any 2300's. The other possibility is that one of the sensors is sticking and reading the paper size wrong, however that would normally trigger an error.
Posted on May 28, 2011
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
May 12, 2011 | HP P4515n LaserJet Printer
Tel me the processedure of duplex printing
Dupoles printing can mean different options in different hardware and software. It can refer to two pges condensed to one A4 in landscape or it can mean odd and even pages on two sides.
Most office suite packags give you the option of duplex in the same way leaving the hardware unchanged which is the best option oveall.
You can printy all ODD pages then reinsert and have it print even pages on the other side and then all you do is colklate them. OR you can print side by side fromn 1- whatever.
By using software option it leaves the printer in its native mode without having to reset ity for the next job
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | HP LaserJet 4250dtn Printer
Cuts off top of back page of duplex
Your problem is in windows not the Printer you have to set the borders and the hight in page lay out, it gets screwed up every time I use it I do not like word 7 the 2003 was much eaiser to use and less troublesome.
Nov 11, 2009 | HP Officejet Pro8000 InkJet Printer
Duplex cuts off top 3 lines of back page
Sorry, I posted that; I didn't think it went through. Please solve it on the other copy,
Did the Laserjet 2550L make duplex prints? if
It is called a manual duplexing option, the bottom rung of the duplexing ladder, you phisically have to take out the peice of paper after one side is printed, turn it over and reinsert it
http://www.retrevo.com/r/258bh050/38/Printing+on+both+sides+%28duplexing+manually%29#q=HP+2550L
Sep 09, 2009 | HP LaserJet 2550L Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
HP PCS 750 cuts off bottom of 8 1/2 X 11 page when printing. Auto reduces page.I need 100%.
The PSC 750 cannot print a full borderless page, it requires a bottom margin of 0.46", a top margin of 0.08" and side margins of 0.25" when printing on 8.5x11 pages.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jul 04, 2008 | Office Equipment & Supplies
Duplex printing
The HP Laserjet 4+ does not have duplex capability built in; you'd need to purchase and attach the duplex unit (HP part number C3157A) to have that option.
Depending on your operating system, your driver may support a "manual duplex" mode in which you print one side, reload the paper, and then print the other side. You can also "fake" this from many applications (such as MS Office / OpenOffice) by telling it to print only even-numbered pages, then printing only odd-numbered pages.
Nov 13, 2007 | HP LaserJet 4 plus Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
HP LaserJet 2300 Printer Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
