Question about Cell Phones
Received order 2 snoopy hard covers for iphone3 no front cover. previous cover had 2 parts. should there be front and back case. should not have to pay for this info
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 104 Answers
Hard cover is only for the back
Posted on May 28, 2011
How can I remove the barrier to install a second optical drive
Two things have to be done in order to add a second optical drive.
1. Open case, remove front cover of case.
2. Remove blank from lower optical drive from front of case - remove blank (chassis part) from optical drive space.
The black insert that can be seen, removes from back on this model.
The 'steel' part on the chassis should pop out fairly easily.
Jan 19, 2012 | Dell Inspiron 620 MT Desktop Computer...
The fans are not working. Would like to have part number to the fans.
The fan replacement is not hard, but it is fiddly.
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the cover and tapping the top of the cover to release the top tabs. Undo the screws on the metal plate which hold the battery in place. Take off the UPS outer metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the location of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan manufacturer's label should face the back of the UPS.
This solution is for a PW9120-1500. I assume your UPS is PW9120-3000 or larger. Check the model of the existing fans.
Feb 24, 2011 | Powerware 9120 UPS System
Need to replace the fan on a powerware 9120T 1500VA
You need to pull out the battery case to remove DC power. To do this - front display cover off by pushing up the plastic tabs inside the bottom front of the and tapping the top of the cover to release the top tabs. Take off the metal case cover using a Torx screwdriver. Undo the 4 screws on the back holding the steel fan cover. Using needlenose pliers or a very small screwdriver, carefully remove the fan connector from the the back PCB board. This connector is fragile and tends to break easily. Pull out the fan. Note the locaton of the 2 screws on the inside fan cover. I use a NMB-MAT Model 3610KL-04W-B50 12 volt DC replacement fan that I order in specially from any wholesale electronics shop as you want the maximum CFM out of the fan. You need to cut the existing fan leads and solder the existing connector leads to the new fan lead, using heat shrink tubing. The connector goes back in only one way- note the dimple on the side. The leads can be a little longer on your completed fan assembly. The fan maufacturer's label should face the back of the UPS.
Jan 20, 2011 | Powerware 9120 UPS System
How do I remove the battery from TomTom One XL in order to replace it?
just remove the 4 screws on the back of the case and split the front and the back halves. becareful when removing the back cover as the battey and speaker are attached to the back cover and the wires are connected to the main board (front half)
the battery is attached to the back cover with two sided tape.
bill
Oct 31, 2009 | Tomtom One XL GPS Receiver
Camera door thats holds battery small grey latch is broken
Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
I have the pro 2050 radio shack scanner and the back light is out. Is there a way to fix it?
1 pull knobs off
2 remove case
3 looking at front pcb remove screws to front face cover
4 carefully remove front fase cover
5 look at LCD there are to small lamps on sides
6 replace lamps
7 replace cover
8 put screws back in
9 put case cover back on
10 put knobs back on
Jun 14, 2009 | Radio Communications
Projection lamp casing melted.
This will be covered covered under warranty by Sony. If you will call 800-282-2848 you can locate a Sony authorized servicer that should be able to repair this at n/c.
Feb 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Want to remove cover of Krups Espressario XP7240
Yes it is tricky but easy once you know it. remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute lid. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. You filter is the white valve connected to the three way valve (white plastic). You remove it by twisting it 15 degrees. Clean the inner parts (valve and spring) from coffee debris.
Feb 01, 2009 | Krups Small Appliances Espresso Machine
We have a baby snoopy bassinete and need a new ******** for it
I was given a baby snoopy basenette and its in good condition however the craddle part slides side to side if you move it, is it supposed to be that way, also i took the covers off to wash them and i cant figure out how to put the canopy back on theirs two bars, a thin one and a thick one, which one goes in the front where the ruffles are?
Nov 29, 2008 | Delta Enterprise Snoopy Deluxe Crib
Cover removal
Front fascia of case is part of cover. Press in side catches and at same time push with thumb on dvd drive - cover will slide forwards.
Jan 01, 2008 | Fujitsu Siemens SCENIC E600 Green PC...
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
