Question about Refrigerators
Ice maker stoped making ice... i think someone removed the ice in the container and then put it back...but i think it is on right.. it sits there ok but i dont think it is real sucure. it comes off easy... is it sapost to click when in place.....
    Problem Solver:
  • 3 Answers
Yes look for a missing piece and make sure the arm is down.
Posted on May 28, 2011
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
I purchased the ice cream maker without a user guide. Is one available?
Are you looking for operating instructions or recipes? Recipes available everywhere ... really. Operating? Here is what you do: Get some ice cubes ... crush them with a hammer ... you will need a lot ... the finer crushed the smoother the ice cream. Put the mix in the metal container and put about 4 -6 inches of ice in the bucket with some water. Put about 1# of rock salt on the ice. More ice ... more salt ... more ice ... more salt ... more ice ... more salt until the bucket is full. Start the machine. Your ice cream should be ready in about 1/2 hour. When the machine stops cranking ... remove the mixer from the can. If you can stand it ... let the ice cream sit in the container for 1/2 hour ... the longer you wait the better the batch. But who can wait???
The ice cools the water, the salt reduces the temp of the water to cause the mix to freeze.
I hope this helps you ... this is how we make home made ice cream every summer ... what a special treat for the kids ... young and old alike.
Thanks for your question @ FixYa.com
Mar 18, 2011 | Rival 8605-M 6 Quart Ice Cream Maker
Ice maker leaks water
Good work thus far. If the ice maker tray that holds the ice is leaking, you need to get a new ice maker. It would never work right if you tried to patch it, and would only cause further headaches. Sounds like you have a little experience which is good. Go down to a local retailer and purchase an ice maker and install it yourself instead of paying someone to do it ;) There is no foul in paying to get it done though. good luck!
May 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Tube dispensing water into ice maker seems out of place
defroose the ice to the plastic white tube and the hole then pull out the tube, then the first end of the tube cut the end like an angle like to make it sharp but only one side then put it back, make sure the tube shoot to hole inside or more better if u remove all the 5 screws and check if in the right way then put all the screws back, ok what out with the small tube if connected properly or loose ok
Jul 29, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice maker doesn't work after removing all the ice.
what do you mean by "giggled the ice container in the door?"
If I get it well, remove the ice container and look for any switch in its holder( where the container touches the refrigerator body). If you find one check if it's not broken, then try pressing/pushing it. If it seems to work normally, put the container back and try to push it towards that switch to make sure it presses it.
I hope I helped
Apr 16, 2009 | Refrigerators
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Ice maker does not work.
Make sure the wire lever is pushed down calling for ice.Otherwise the unit thinks its full.
Jan 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Feb 11, 2007 | Kenmore 53632 / 53634 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
