I got a error message on my samsung remote control (BN59-01134B) which is "BT ERROR", What shoud I do? I tried everything!
I got a Samsung 1080i television, but when i connect my dvd player to the back, it does not pick it up. i also tried connecting a tv freeway antenna and that did not work either.
Check the input selector. If it is not set to use the source signal type, the set won't pickuup any signal. If the source signal is antenna, you shoud select antenna as input selector. If the source signal is AV, you shoud select AV in the input selection. Press the input button at the remote controller, and do the needy.
May 31, 2017 | Samsung Televison & Video
Bt error
Put in fresh batteries. You have to pair the querty side of the remote again. Go up to your samsung smart TV 8 inches or less to pair. Press SYM and TAB at the same time. You should notice on the querty screen that states "Pairing." Your TV should confirm. The keyboard will load up when you press a key. Follow information on TV screen. Some applications like Netflix do not work with the remote. You can use your Querty side when you press on an app. Scroll to any app. If a screen pops up like for web browsing just type like a keyboard.
Dec 06, 2013 | Samsung BN59-01134B Remote Control...
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
Pantech Link P7040P "Initializing Message" Error
add 'conversations' to your shortcut list, go in through shortcuts menu and delete everything in there, ONE AT A TIME. hitting 'delete all' will freeze your phone. found this out on my own since no one knows what the hell is going on with these phones.
Jul 05, 2012 | Pantech Link P7040 Black Rubber Feel Hard...
My Harmony 1000 will not communicate with the home site.
1) Will be a good idea to contact customer service, for guide you. Because the USB cables can be faulty. You must know something about the electronic for test this special wires.
God bless you
Jun 13, 2012 | Logitech Harmony 1000 LCD Touchscreen...
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
It says "loading" then it says
try using a lens cleaner first which can be bought from your local multimedia store and run it a couple of times that shoud solve the problem if it still fails just message me
Apr 15, 2011 | Samsung HT-P38 System
Ok, if try to open my Contacts I'm getting an error message saying "Not enough memory to perform operation. Delete some data first." I am getting this same error message on virtually every...
since you tried everything..let me give yu the ultimate solution
1.go to file manager and backup phone on memory card and remove it
2.go to settings<phone managment<factory settings
3.enter password and reset the phone
4.after resetting insert memory card and restore
Mar 05, 2011 | Cell Phones
Televison & Video Logo
1,181 people viewed this question
Top Televison & Video Experts
