Question about Averatec Computers & Internet
I tried to restart my computer: an averatec n3400 series again and again but only get windows recovery error. I don't know what to do
    Sergeant:
  • 246 Answers
Try to System restores mode, if still error try to reinstall your windows.Thx
Posted on May 28, 2011
How do I correct the problem code C 0000001 on Windows 8 operating system
Solve Error Code 0xc0000001 in Winodws 8 Team Windows 8
Windows 8 Blue Screen of Death (BSOD) or Error Code: 0xc0000001 sometime occurs without any specific issue. You can't be sure what actually caused it. Be it a system issue or some driver problem, you may end up seeing this screen when you restart your computer.
To solve this blue screen error in windows 8, turn off your computer and when you power it up again, immediately press SHIFT + F8 key you will be resented with following screen:
Click on "See advanced repair options" and from the next screen, choose "Troubleshoot":
On the next screen, choose "Advanced Options"
In Advanced Options, choose "Windows Startup Settings"
There you will find a button "Restart". Click on this button and allow the wizard to complete all the steps. Note that it will repair your computer without making any changes to it. Once the process is completed, your computer will automatically restart and you should be able to boot windows now.
Still facing same error?
If you have followed all the above mentioned steps but got no luck in booting up your windows then probably your cause of the error is more solid and cannot be restored with mere settings reset. But don't worry, it can still be solved using windows recovery options. For this you should have a recovery/installation disc or USB Flash Drive.
Windows 8 Recovery Guide Recover When Windows 8 Fails to Boot Team Windows...
Jul 07, 2015 | Computers & Internet
Bootmgr missing error on startup
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
ERROR 305: 69
Most times the Recovery from cd's don't work. You'll be better served by doing a Reinstall of Windows.
System Recovery (sometimes referred to as Factory Restore) will set your system back to when you first purchased it. It Deletes Everything. Most times the System Recovery does not work unless there is a recovery partition on your hard drive created by the manufacturer. If you are trying to recover from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall Windows. Look on your computer for the Certificate of Authentication (COA) Sticker. It will tell you what operating system is on your computer and it will give you the Product Key Code (a series of 5 letters and numbers) that you will need to activate windows. If you don't have an operating system disk, borrow one from a neighbor, friend, relative or co-worker. Just make sure it is the same as your COA Sticker's operating system or it will never activate. Also make sure you get the COA Product Key Code for the disk you borrow because sometimes the system will ask for the one that is on your system and sometimes it will ask for the one from the installation disk.
Jun 08, 2012 | Computers & Internet
Did recovery, error message: encountered unexpected error
If you made backup recovery cd's do a fresh install of the operational system to factory setting.
Apr 17, 2012 | eMachines EL Computers & Internet
When i switch my computer on, windows profession window appears and say press ctrl+alt_delete to begin, I do that but nothing happens. My laptop i'm using is a Dell Latitude D630
Step 1 - Remove non bootable media
Remove any floppy disks, CD's or USB sticks from your computer and restart.
If NTLDR is missing error appears again, Do the Next Step.
Ensure you boot the system from the CD. The system will then boot into the Windows XP Setup.
At the welcome screen press 'R' to enter the Recovery Console
At the recovery console, select your Windows XP installation and enter your Administrator password if requested
At the command prompt issue the following commands and press ENTER after each command:
fixboot
fixmbr
Remove your Windows XP CD and restart the computer
If the NTLDR is missing error appears again after reboot, Try the Next Step.
It is sometimes necessary to run or re-run the Windows XP Setup repair process
If it did not solve your issue re-insert your Windows XP CD and run Windows Setup again
Good Luck!!!!
Sep 20, 2011 | Computers & Internet
When i try the acer system recovery it keeps coming up with an error that says windows could not install and setup with resume when computer restarts..restarts ands same box pops up? cannot get past that...
Have you tried booting to the system recovery again and starting it over? Otherwise you may need to wipe it clean and start from scratch. Download a program like Darik's boot an dnuke to wipe the hard drive clean (this will destroy all data on the hard drive, including system recovery data if that is saved on the hard drive instead of CD's.) Then try the system recovery again (if it's on CD's)
Jun 24, 2011 | Acer Aspire One PC Notebook
I have the averatec N3400 and i don't know how to find my webcam. when i am on the internet it pops up but without the internet it doesn't work and it cant even find it. What do i do?
Install a webcam software in your computer - there are several - use Google to search. Check with the Averatec website if they have one for your webcam to download and install. Also, you can access the webcam through the Control Panel with Window's generic application.
Jan 20, 2011 | Averatec Computers & Internet
Lost Installing CD cant install to windows XP my computer is averatec 3200 series
here they are , I could not find free cd:
Averatec 3200 XP Windows Driver Recovery CD Restore DiskThis is an automated 3200 XP drivers recovery cd. The 3200 drivers are supplied in a special windows friendly format. This means that your Averatec 3200 XP Laptop will automatically find and install all the drivers for your system, with hardly any user interaction. If you have installed a new windows operating system and half of your Laptop just wont work (with errors like no sound no internet or bad graphics) then this is exactly what this CD has been designed to fix repair. You can also use this CD Disk If you just need to return you.....lots more averatec 3200-series drivers information here.
http://www.user-guides.co.uk/Averatec/AveratecDrivers/Averatec.asp?keywords=Averatec+3200-Series+Drivers&recor=1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Windows dont start
Averatec is famous for not supporting their laptops after they sell them. If your system is giving missing files after a full restore, it's possible you've got some bad hardware. Try running a memory test by downloading memtest86+, and burning it to a cd. It will need to run overnight. If you've got bad ram, replace it. You can also test your hard drive by downloading the support softare for your specific brand of hard drive. Maxtor used the maxblast, western digital used powermax, and hitachi/ibm uses another, but I can't remember the name. Try those, and let me know.
Steven
Sep 17, 2008 | Averatec 6200 Notebook
RESTARTING COMPUTER(AMIGOS)
hi powee;
have you recently installed some device driver?
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
here is the link;
http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/w2000Msgs/6077.mspx?mfr=true
hope it resolves your problem
Jun 19, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Computers & Internet Logo
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
