Question about Electrolux Vacuums
Electrolux 2100 canister vacuum. Motor replaced 5 months ago. Now bag 1/8 full caused full bag light to trip. With new bag, placing hand over suction inlet trips full bag light. Is there a hi-current or other motor voltage strain device or circuit to detect the motor needing to draw more?
  • 11,800 Answers
The bag full system is a simple one, based on air pressure: a spring keep a plunger in balance in a cylinder open at both ends - one end inside the vacuum chamber (where the fan of the motor is situated) , the other connected to the outside air. When the difference between the pressures is larger than the full force of the spring the plunger is sucked all the way to the bottom of cylinder where it triggers the warning switch. So placing the hand over the inlet will surely trigger it even in a new one. This system has no connection with the motor, no influence on it whatsoever.
You get this error because either the spring has aged and no longer opposes the correct resistance and the entire system will have to be replaced or there is a blockage on the air pathway - from the brush all the way to the fan. To find the blockage you will need to inspect the brush, hose, connector filters and the fan itself .
Extensive dismantling of the vacuum unit will be needed for that, if you don't know how to do it then you will have to take it to a repair shop.
Posted on May 28, 2011
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux 2100 does not turn on. the light bag full comes on even with a new bag
The bag might not be seated properly or you are using the wrong type bag.Try reseating the bag.
Jan 20, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Dec 16, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Full bag light on when bag is new
Check for secondary filter, if it is clogged could cause bag light to come on as suction is dropping due to filter, not bag.
Dec 08, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
250 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
