After installing a new graphics card in my computer I get " To use advanced dot placement mode select a border paper size and load the paper tray with genuine Kodak Gloss photo paper and run the print job again. All I am doing is trying to print one line "This is a test" in microsoft word. It worked fine before the new video card PCI 256 MB VSA/DVI was installed.
  • 4 Answers
That doesn't seem like video card issue it sounds like a printer driver issue. Check your print settings and make sure it's set to simply black and white or just color....and uncheck advanced dot placement mode.
Posted on May 28, 2011
Borders on external monitor after Dell Latitude D630 wakes from sleep
Thomas Motley,
Your monitor is displaying like it is because the graphics card refresh rate has changed. Check that the display driver is correct for your graphics card and that you are not using the generic windows driver. If the driver is correct then look in desktop properties, settings, advanced, monitor and check that the refresh rate is correct for you monitor.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 27, 2013 | Dell LATITUDE Computers & Internet
MSI N1996 motherboard with 640gig sata drive / sata DVD ROM / NVIDEA Graphics card G7500 - wont boot up windows 7 even though i install new sata drive and try new installation it wont boot up! Pre...
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
Nov 17, 2017 | Intel Motherboard
I have a window XP and it is not built-in video card. i insert Nvidia GFX 5500 but my monitor did not respond. can you help me?
Goodday!
Have you check already the AGP size of your motherboard? Check it first if it is compatible with you Video Card..
Thanks and Godbless!
Mar 28, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Since installing this graphics card I've had a shadowing issue. Being a new graphics card I assumed it was a problem with my power supply. I replaced the power supply and I still have a shadow on every...
Maybe the new card supports more of XP's graphical features and the shadows might be a feature.
This border on desktop icons can be created when the desktop items have been locked, to unlock the desktop web items right click on an empty area of your desktop. Now select Arrange icons by and uncheck 'Lock web items on desktop' if it has a little tick next to it. If you did not have a tick here then Right click on your my computer icon and view its properties, now click the advanced tab and then on the settings button under performance. Now on the visual effects tab scroll down the list of effects to 'use drop shadows for icon labels on desktop' and put a tick in the box next to it, then click ok. This should remove the shadow border from your desktop icons.
Jan 12, 2011 | BFG Technologies GeForce 9800 GT, PCI...
I try to print a letter on basic settings and the Printer will not print. An Error screen pops up stating . "the print job cannot be completed - To use the advanced dot placemment mode, select a bordered...
Basically the problem is caused by the printer spooler which is a printer system file that was installed on windows XP
For this problem kindly try doing the ff:
* click START then select RUN
* Type net stop spooler
* Type net start spooler
* Then try printing
* if problem still persist call 1800 421 6699
Hope this will help
Thanks
Byron
Sep 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Cannot load template to Sony UP-CR10L, how can I copy the custom made tempalte to CR10L?
You need to copy the border you created in the border creater software to a border folder on you computer that you have created to store you borders in.There is a folder on the CD that came with the machine that
I would suggest you copy to your hardrive as this will need to then be copied to a compact flash card that is then installed in the expansion slot on the inside of the ribbon carrier door.If you save your new border to the folder on you hardive you can always back it up at anytime.If you
print different sizes you will need to create a border for each size of print. Once you have installed the card in the machine switch it on and
go to the print option screen and you will see the border ikon is not greyed out but now active simply select this option and the the border you require.Then it should print.
Sep 18, 2009 | Sony SnapLab UP-CR10L Digital Photo...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Perpixel rendering related problem
The IGP in VIA/S3G UniChrome Pro IGP stands for Integrated Graphics Processor. The WindowBlinds error message indicates that onboard graphics tend not to support per pixel acceleration. There's your answer: your graphics cards do not support this kind of advanced processing; unfortunately a driver update isn't going to solve the problem, as it's hardware-related. You will need to upgrade to a more powerful card if you want to use the translucent borders.
Regards,
Javabytes
Nov 11, 2007 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
