Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Tb144 pull cord stuck out on mini tiller edger 26 cc 4 stroke
5 Suggested Answers
lilmikew99
  • 122 Answers
SOURCE: TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
Posted on May 11, 2009
  • 115 Answers
SOURCE: trying to put on pull cord on tiller.
you remove the cover, bend three tabs and the wheel will come out. Replace the cord in the manner that it is removed, rewind spring and install wheel, then bend the tabs back down.
Posted on Jul 04, 2009
SOURCE: Troy-bilt 4-cycle Garden Cultivator TB144 pull
This type of pull starter design is very poor and fails often. Cheap parts and cheap design leads to poor performance and yet Troybuilt still doesn't give free parts or an upgraded design.
Posted on Jul 25, 2010
SOURCE: I have a troybilt tb-144 4 stroke mini tiller.
Troy bilt TB144 loses compression won,t start. Help
Posted on May 10, 2011
Mtd cultivator
take your cover off then you take off your spinny thing out and take the old rope off the spinny thing and tie your new rope in it then twist it tight if its old or if its new dont worry its auto set then put it all back the way you took it off
May 07, 2013 | Troy-Bilt Troybilt Mtd Mini Tiller...
Oil coming out breather
It possible that the PVC is stuck closed or the hose attach form the PVC to intake manifold is either pinch shut or the hose has
collapsed, not allowing the crankcase to have a negitive presurre. The other possiblity is the cylinder rings may have to much blow by thus forcing the oil out throught the dip stick tube. Check the PVC system first.
Mar 24, 2013 | Troy-Bilt TB144 26cc 4-Cycle Gas-Powered...
How to change primer blub on craftsman mini tiller?
I suppose this is on the 4-stroke mini tiller. There is a circular retaining washer with "tangs" on it in the bulb housing area. Clean the area well and you will see it. It is black probably. Use a very small screwdriver and reach in and pry it out in a few different spots and it will pull free and so will the bulb. Insert the new bulb and the the retaining washer making sure the tangs on it are all nice and flat. Press it back into place with the same small screwdriver being very careful not to puncture or tear the new bulb.
Nov 07, 2010 | Craftsman Gas Mini - Tiller/Edger
How to remove clutch?
You have to pull the spark plug and fill the cylinder with some small rope then using a big pair of locking pliers you can loosen the clutch. There should be markings on the clutch as to the direction to unloosen.
May 13, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
I have a troybilt tb-144 4 stroke mini tiller. The pull cord, pulls and retracts as it should, but is not engaging the engine when pulled...
remove the top cover. look inside while pulling rope briskly, you should see two dogs fly out and retract when the cord reaches its end. if not, check for dirt in the system and clean out. if no dogs, you will have to remove the system from the housing, be careful of the spring. check for any broken drive parts. also check flywheel cup for damage where the dogs come into contact with it.
Apr 15, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
Engine manual for troybilt tb 144 mini tiller
Below are a few links that might prove useful. The first two are operators, and shop manuals for the 144. I briefly looked through them and they have engine related info. The third is just an exploded view of the engine.
Hope this helps.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb144_1.html
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/4cycle.html
http://www.partstree.com/parts/?lc=troy_bilt&mn=21AA144R966+TB144+Cultivator+%282006%29&dn=769021900001
Sep 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
May 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
109 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
