Question about Dryers
Kenmore 80 series 66814690 electric dryer
I have a Kenmore 80 series 66814690 electric dryer that appears to be working fine. No noise, Dryer Tumbles, Dryer heats up but clothes are wet.
I've noticed alot of humidity when opeing the dryer meaning that the exhaust must be clogged. Since I replaced the vent ducts with new ones I know they are clean. Troubleshooting the issue, I noticed that cool air is coming out of the exhaust instead of warm even though inside the dryer is hot. The lint tray is clean, I ran a dryer/vent cleaning brush up the exhaust to see if it was clogged... it came out clean. Where else would it be clogged?
Thanks,
David
  • Floyd_Droid Aug 16, 2008
    I took apart the exhaust shaft, and low and below the clog was the size of a Chiuahua. No wonder I picked up this dryer for $50.
    See pictures below
    Thanks
    David
  • 126 Answers
SOURCE: Kenmore 80 series dryer
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Posted on Dec 14, 2007
  • 131 Answers
SOURCE: Auto dry not working
If there is a dryness sensor, it will be just inside the door, on the bottom right. You can clean the sensor by rubbing the metal bars with a scrubbing pad. This will remove any wax buildup from fabric softeners.
Possible reasons your clothes may still come out wet:
1. The dryer isn't tumbling the clothes.
2. The dryer isn't heating.
3. The airflow is restricted.
From your description, the third seems most likely. If your machine is the one pictured above, inside the dryer door is a plastic grate over the lint screen. Remove the lint screen. Remove the two screws on this grate (Phillips.) Use a vacuum cleaner with a crevice tool to get out as much lint as possible. Be careful to not shove any lint or debris further down into the blower wheel.
Lint can also clog up in the vent pipe. This pipe should be cleaned or replaced anually. Also, check the exhaust vent on the side of the house.
Posted on Mar 10, 2008
SOURCE: GE DPGT750 Gas Dryer runs but no heat
my dryer runs but it doesnt get hot and drys my clothes what could be wrong
Posted on Mar 10, 2009
  • 3600 Answers
SOURCE: I have trouble with lint clogging up vent duct,
make sure the hose is short as possible and be sure you have long sweeps on turns not tight 90's as the tight 90s or bends slows down the velocity of the air thus causeing the ling to drop into the pipe.
Posted on Nov 09, 2009
SOURCE: my kenmore 80 series dryer won't heat but
Had similiar problem once and it turned out to be one leg of the 240 volt
supply was dead. The drum motor only needs one leg (120V) to run, but the Heating elements require both legs (240v). Make sure you have 240V at the recep.
Posted on Nov 27, 2009
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 | Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series HD+ dryer will not heat. dryer runs and tumbles fine just no heat
Check thermal fuse behind the dryer by opening the back cover.Fuse is on the air duct.
Jun 18, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Location of the thermal fuse on the kenmore gas dryer 80
Feb 03, 2009 | Dryers
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Dryers Logo
620 people viewed this question
Top Dryers Experts
