Question about Canon Speedlite 420EX TTL Flash
Just stopped. Batteries fine. No powering up sound. Not dropped, wet, etc. just quit.
  • Canon Master
  • 3,083 Answers
The xenon flash bulbs, capacitor, or small high-voltage transformer can go bad, and the unit will die. You can replace these components, but it's not easy or fun. You can ohm out the bulb and transformer to usually eliminate them, when change the cap first.
Make sure the battery contacts inside the unit are perfectly clean, and free of any battery chemical leakage or oxidation. You can use a qtip and alcohol, or fine grit emery cloth, if they're really bad.
Other than that, get the ohmmeter out. Make sure the flash capacitor (small, barrel shaped component) is totally discharged by shorting it out with a screwdriver, or other metal object. Short it out 3 times, just to be safe...about 5 seconds apart. The transformer and bulb should appear to be mostly shorted. In that case, try the cap. Then transformer, and lastly, the bulb.
Good luck, and hope this helps.
Posted on May 28, 2011
Swiffer wet jet stopped working.
Check the battery output, or take your jet to someone to open it for you to check the connections on the battery slot.
Jul 14, 2017 | Cameras
VO37LHDTV10A 37 in Remote malfunctioning
Cheapest route is to get a universal remote and start over. Most remotes have their life span. Sometimes shorter. Any abuse of the remote by dropping, getting wet, etc will make it quit. Hazards of a little piece of equipment we don't see as important UNTIL it does not work!
Mar 06, 2014 | Vizio VO37LHDTV10A 37 in. LCD TV
I have a sakura electric bike and when I use the throttle the battery charge indicator drops to empty and it cuts out, however when I stop the charge indicator rises again. Any suggestions.
Sounds like your batteries are low in capacity and need replacing. The battery indicator is measuring voltage. As you draw power from the battery the voltage is dropping (sagging) because the batteries are weak/old. When you stop drawing power the voltage rises again.
Aug 12, 2012 | Electric Bicycle Motor, Bike,electric...
The washer does not spin all the water out ,clothes remain quite wet
is your pump blocked? sometimes hair clips or money etc get stuck in the pump and stop it pumping effectively.
Jun 18, 2012 | Washing Machines
1995 c-220 that seems to not hold it's rpms when it rains or gets wet. When the car is warm or dry it idles at 750 and is fine. When it gets wet it drops to 100 and stalls allot.I have to put it in n to...
Hi, sounds like you have a spark tracking problem caused by damp etc, worth spraying all HT system with something like WD40, if that stops it going on to three cylinder it will prove you need to renew parts of your HT circuit etc, good luck.
Feb 24, 2010 | 1995 Mercedes-Benz C-Class
Power button stucked
presumably it got wet, or was something else involved like glue, sand, coffee, etc. Make sure the batteries work, since power is required. You might try a small drop of vinegar, which might be enough to eat through any sticky substance. give it 15 min, and try again.
Apr 21, 2009 | Casio Exilim EX-S880 Digital Camera
Remote control
Has the remote been dropped on any hard or wet surface?ie. on the floor or a bucket with water.
If it felt on the floor, maybe some wire has unplugged / unwelded.
if felt in a wet surface it needs to be open and dry without the batteries on.
Sometimes the old batteries expel a very corrosive fluid. Verify that the old batteries had no rusted the contact leads of the remote.
if they did, clean the leads, do not damp them.
Good luck!!!
Mar 02, 2009 | Durabrand 5.1 Surround Sound Computer...
Vertical whitish lines on lcd display and on pictures
What is the make and model of the camera? It sounds defective. I work for a digital camera manufacturer and we have the same thing. Probably will need to be replaced.
Feb 01, 2009 | Nikon Coolpix 4600 Digital Camera
Wheelchair battery Question
Wet batteries will require you to add distilled water about once every two months. Wet batteries can be damaged permanently if the water level falls below the level of the battery plates. Adding water is quite difficult for the wheelchair user because wet batteries are heavy and difficult to reach, so it usually requires the help of a second person.
Gel batteries don't require water, so they eliminate corrosion. The main disadvantage of gel batteries is that they usually cost more and have about 10 to 20% less capacity than wet batteries do.
Sep 14, 2008 | Drive Medical 19 Aluminum Transport Chair
LG VX6100 - Won't stop vibrating
my phone barely got wet at all but wont stop viberating either.everthing else works fine. i set it on a table to go on the computer and the viberating just stopped and i dont know why but right after that it just started viberating again. i got some tips from some other people that didnt work 4 me but it might work 4 u. u could try doing a master reset which just taking out the battery when the phone is on and it resets or u can try blowing on the battery in case it somehow got some dust on it.
Oct 21, 2007 | Cell Phones
Canon Speedlite 420EX TTL Flash Logo
212 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
