Question about Microwave Ovens
Want to remove an old jenn air microwave Model # M438B. Removed the screws in the cabinet above but its not budging. What do I do?
    President:
  • 2,080 Answers
There are probably a couple of long bolts still holding it to the brackets on the back wall.
These long bolts are usually accessed through the removeable grill on the front of the microwave.
Just pop off the front plastic grill and then unscrew the bolts underneath. Be sure you have someone to support the full weight of the microwave when you do this since it will probably drop down once you remove these 2 long bolts.
Here is a link to a few other articles with some more tips:
http://wiki.answers.com/Q/How_do_you_remove_an_over-the-range_microwave
http://hubpages.com/hub/how-to-install-installing-an-over-the-range-microwave
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 28, 2011
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
How can i disassemble a jmc7000adw
Although most open via a screw at the top or left side of the control panel.
Some require the cabinet / casing to be removed. If there is no visible screws at the top or sides of the control panel. Then the casing will need to be removed.
Mar 27, 2012 | Jenn-Air JMC7000 Microwave Oven
My father's old Jenn-Aire microwave, Model # M170, has a rusted bottom and we need to replace it. Is there a model that is of the same dimensions so that we can replace the unit inside the cabinet above...
You can contact Jenn-Air customer service and they should be able to tell you if there is a "drop-in" replacement for your model.
Aug 19, 2009 | Jenn-Air Microwave Ovens
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I can't remove my GE spacemaker microwave from the wall
should only be two phillips head screws in the grill holding it.tilt top out first and lift out. if the metal above is smashed down on grill the screws thru the bottom of upper cabinet need to be loosened,< not removed just loosened > and this should help. Some models slide one way or the other to release tabs also.
Apr 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn-Air Microwave Bulb and Filters Inaccessible - Design Flaw - Help!
It's not a design flaw. The microwave was incorrectly mounted.
The installation instructions (installation kit) included a template for proper alignment of the microwave on the cabinetry.
If it had been aligned with the template, the two top grill screws would be easily accessible.
The grille must be removed to access the lights and the charcoal filters, which should be changed every 6-12 months if they are used.
If they are in place and not changed regularly, critical ventilation and cooling can be affected.
Your owner's manual can be downloaded free here, and it shows you how to change the bulbs and filter.
It will have to be remounted properly.
Nov 06, 2008 | Jenn-Air Microwave Ovens
Removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Aug 27, 2008 | Microwave Ovens
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
Jan 31, 2008 | Microwave Ovens
Microwave Ovens Logo
98 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
