Question about Refrigerators
Maintenance requirements for a elkay model ers1 1e aqua chill cold water dispenser
  • 409 Answers
SOURCE: water from chilled water dispenser on my amana side by smells bad and tastes bad
its either the icemaker itself or could be water actuator padle needs replacing.
Posted on Sep 13, 2008
SOURCE: Water Dispenser Temperature not acceptable
This is a brand new refrigerator - I cannot solve the problem and I am returning the refrigerator to the dealer. Thank you, but I am not paying $ to fix a new refrigerator. I have tried everything.
Posted on Feb 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: need temp control for water cooler has BOTH HOT/COLD
Company called Ranco makes replacement contols. Contact your local Appliance Parts Dealer.
Posted on Apr 22, 2009
muralme
  • 20 Answers
SOURCE: elkay water cooler does not turn on
You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
Posted on Jul 17, 2009
  • 127 Answers
SOURCE: water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Posted on Oct 18, 2009
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-ArcĀ® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
Jan 14, 2016 | Elkay Plumbing
Water fountain elkay model # edfp17c
Feel the water coming out of it to determine if its the cold water side of the hot. More then likely you broke something and to determine what it is will require you to remove it. Home Depot has sink bolt removal tool that makes it much easier. After you find where the problem is then contact manufacture and usually they will send you free parts to fix or complete new one.
Mar 12, 2014 | Elkay Home
Hot/cold water dispenser. Why is cold indicator blinking and no cold water dispensed?
We typically service Hoshizaki, but you may not be getting water into the resivior. Depending on model, you may need to remove bottle and probe and check the silicone seal, reseal and re attach. Also be sure that hoses are connected and fully pushed into the connectors. And of course make sure you have a water supply. Could take up to an hour for water to re chill again. Hope this helps. Check out our site for other product and tips! Thanks! www.whiteswarehouse.net
Jan 18, 2011 | Whirlpool GI15NDXTSS
No cold water
Most refrigerators with a water dispenser have a reservoir (tank) to chill the water before it gets to the dispenser. This tank is typically behind the crisper bins so the water should be the same temperature as the refrigerator. The water may start out room temperature but should be cold by the time you have filled 1/2 a glass or so.
Saying all that, there are a few newer models out there that have reduced the cost of the refrigerator by eliminating the reservoir. If you take the crisper drawers out and look behind them and do not see a tank or coil of tubing then you do not have chilled water.
I hope this helps clarify.
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
French door model installed yesterday with outside water & ice. the water is not cold from outside dispenser. have freezer set at 0 F and frig at 35 f
theres only so much water that resevoir inside can hold once it empties it must sit to cool or chill. once used then ur just gettin straight water from ur water line from the house...
Jan 28, 2010 | Electrolux Refrigerators
Water through dispenser not cold.
The first half of a glass will not be cold. The cold water has to travel from a tank behind the veg drawer. But if this is a refrigerator with the freezer on the top then it won't have chilled water.
Jan 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispencer dribbles the water out.
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
