Question about Campbell Hausfeld Air Tools & Compressors
Compressor was running and made a loud "pop" and
  • bjlady18 May 29, 2011
    Thank you for posting back – The cylinder sleeve show’s no defects, and the replacement piston sleeve assembly part number for this unit is # WL211000SJ, comes in at just under $50.00 with shipping. What I have done is take the seal and straighten it back out, and turned it inside out. It did build air back to 125, and shut off, (this time) but I will never trust oil less compressor again, this cheap unit (designee) can’t take the requirements of a spray gun, even though it is rated for it. The seal blew just after I added hardener to ½ gal of synthetic enamel auto paint, causing an additional loss of over $100.
    The unit / one owner / is - out of warranty – but it was gently used to air tires, blow dust from computers and run an impact gun once every 6 month’s.
    President:
  • Campbell Hau... Master
  • 1,388 Answers
Take a close look at the top of the cylinder and see if it is pitted or scratched. Usually the cylinder will cause the ring to blow backwards if there is too much clearance or pits. If however the cylinder is smooth, then you must have factory defect. Even if out of warranty, email the company for help. If no joy you can replace the cylinder /piston for about 40. dollars. Order parts from www.chpower.com. Other brands use this type of cylinder including porter cable, craftsman, coleman, ridgid, most oil free type of units. The porter cable units do have only the plastic ring available, however it is very short lived is the cylinder is even slightly worn. Good luck.
Posted on May 28, 2011
Air compressor makes loud knocking nois when running
remove shroud and see if fan is broken but may be piston is shot
Apr 10, 2013 | Craftsman 33 gal Air Compressor 6 hp...
Similar to another persons question...have a circa 1995 cambell hausfeld piston type compressor, has been great for past 17 years. it was building pressure, albeit the source at the tire fitting...
Woody:
Your compressor is losing pressure somewhere... check both ends of the air tube between the compressor head and the tank. The loud pop may have been the packing at one end or the other. You'll have to remove the head again to remove the air tube, but I believe your problem is the pressure seal at one end of the tube or the other.
Mar 11, 2013 | Air Tools & Compressors
Air Compressor will only pump up to 35lbs.
The two main areas to inspect if your pressure isn't going over 35psi are the valve plate and piston/cylinder assembly. If the reed valves on the valve plate are bent, warped or broken, usually attributable to high heat, they won't seal well enough to get higher pressures. If the cylinder is badly scored or the piston and/or piston rings are damaged, usually attributable to running the pump motor with low or no oil, the seal between them won't be good enough to get the pressure any higher.
Aug 13, 2012 | Craftsman Air Tools & Compressors
Compressor motor runs but does not make compessed air
Some of the things for you to check are for any leaks anywhere, the valve plate assembly, the piston and cylinder assembly and the con-rod. If you have any leaks that let air out as fast as the piston is trying to pump it in you won't get any compressed air. Check the drain valve on the bottom of the tank and the air line from the pump to the tank. If any of the reeds on the valve plate assembly are bent or broken they won't seal the way they need to in order to compress air. If the cylinder is badly scored or the piston rings are scored or broken the piston won't pump compressed air into the tank. If the con-rod is broke the piston won't work at all.
Jul 25, 2012 | Makita Mac5200 138a 3 Hp 5 Gal Wheeled Air...
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
Unit runs constantly but only reaches 45psi. Compressor doesnt sound the same either. All lines and couplers seem ok.
If you are only getting to 45 psi, you have a problem with either your reed valves or piston rings/cylinder assembly. If you feel comfortable taking it apart, removing the head(s) on the pump will let you inspect both to see which is the problem. The reeds on the valve plate have to be in perfect condition. Buildup, broken or bent reeds will prevent them from sealing so air can be pumped into the tanks. If the seal (oiless) or rings (oil lubricated) around the piston are damaged the same result will occur. These can be indicated by excessive wear marks on the cylinder or stray peices on top of the piston. Both are simple fixes and fairly inexpensive. Without your model number I don't know which parts to recommend. On Ridgid's website they have an excellent parts lookup system and you can order from them or use the part numbers to check other websites for prices.
May 26, 2011 | Ridgid r Factory Reconditioned 325 HP 45...
My compressor motor will run a long time and not get the pressure over 80lbs.
Depending on the model that you have it is more than likely the piston seal/rings or the reed valves and plates. You should be able to remove the pump head and inspect these two parts to see if there is any damage. Be advised that once you remove the head you may have to replace the gasket because it may get damaged.
Oct 30, 2009 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
2005 chevrolet venture load levelers not working
had the same problem with my ford a few years back, found that the rubber seal on the piston in the compressor had run dry and it was too hard for the compressor to push the piston up and down the bore which cut the power to the compressor and you had to stop the car turn it off for a couple of minutes and restart it and the compressor would pump air for another couple of minutes and stop again.
I solved the problem by replacing the shocks with a pair of pump up shocks that have a valve like a tyre valve and you pump them up at the service station
hope this helps
May 25, 2009 | 1999 Chevrolet Venture
Air Tools & Compressors Logo
118 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
