Question about Vitamix Super 5000 Work Top Blender
I was blending a slightly thick batter and the Vitamix just stopped! Will the machine start after awhile? Do you think it has just overheated? How do I find out ? My old Vitamix had a reset button at the back,this one doesn't,please Help!
  • 206 Answers
Well it might just be over heated, let it cool for approx 20 minutes then restart if it doesn't then u may try switching electrical outlets, if that doesn't work then it needs to be replaced. I hope that this helps, if not please let me know and i will try and help you out as much as i can.
Posted on May 28, 2011
  • 1 more comment
  • shylagowdar May 28, 2011
    I waited for 30 mins and tried again,it 's working fine,thanks for your help
  • Lauren  Castro
    Lauren Castro May 28, 2011
    Anytime
  • twgrindle Jul 31, 2011
    I have left my VM off for over an hour - still won't turn on. Any suggestions? It is a refurb, and I have only had it a couple months.
Need a vitamix VM0115A MANUAL
http://kitchen.manualsonline.com/support/vitamix/blender/manual-for-vitamix-vm0115a-5036806
Apr 12, 2015 | Juicers
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Mar 31, 2015 | Vitamix 5000 Work Top Blender
My blender goes on and off
I think your best bet with a machine like yours is to contact customer service.
Check here:
Contact Us Customer Service Vitamix
Mar 12, 2015 | Vitamix Vita-Mix Blending Station Advance...
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
I have this model and a vita prep 3. Both turn off when tasked with heavy blending. Is there anyway to increase their blending torque capacity? They used to be much better. They are not old machines.
The motors even if they not old blenders if they have work with too much load for along time then they have been overheated and thus they will trip overheat safety more sensitive. So now actualy you have less blending torque as you have describe. So now their is much posibilty if you continue to work it the same way you will finally burn the motor rotor so the damage will be grait.
So now not only you can not get more torque but you should try to avoid very heavy use in order to have them work for a longer time.
When you use with a lot of ice cubes try to cover them with a lot of liquids and always use the pulse mode to start ant the continues rotation.
Good luck
Aug 14, 2010 | Vitamix 1003 Vita-Prep Variable Speed...
Vita-mix Blender will not power on
We just had this problem.  Called VitaMix and they talked about resetting the thermal protection switch inside.  They suggested lifting the base down firmly, but gently, on the counter to help the internal switch reset.  I did it while they were on the phone and, sure enough, the machine came back to life.  Hope this helps.
Mar 29, 2009 | Vitamix TurboBlend 4500 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Vitamix Super 5000 Work Top Blender Logo
1,022 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
