Question about JVC Audio Players & Recorders
Jvc r1x receiver no balance control, bass and treble give loud output
SOURCE: RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Posted on Dec 04, 2007
  • 119 Answers
SOURCE: DENON 2308 - altering the Bass and Treble
IF YOU HAVE A MANUAL PAGE 40 DEALS WITH HOW TO DO THIS
Posted on Mar 02, 2009
smarthome2
  • 1114 Answers
SOURCE: How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Posted on Jul 01, 2009
  • 489 Answers
SOURCE: manual for KLH R7000 receiver
i searhced for a manual but i couldnt. i havve link maybe it works for you
check it
http://www.receivertech.com/klh-r7000-61-channels-receiver.html
Posted on Nov 02, 2009
budmrtn
  • 11361 Answers
SOURCE: adjusting bass and treble
You can download manual here and see what it can do without remote.
http://audio.manualsonline.com/manuals/mfg/panasonic/panasonic_sa_saxr25.html
Posted on Nov 10, 2009
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Zone 2
I would consult your owner's manual but I don't think you can adjust the bass/treble levels on the zone 2 outputs.
May 21, 2013 | Denon DRA-397
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
How come when i push the "A-M" button to use my sound controls all i get is the balance and the fader? no bass and no treble
You can only use bass and treble if your Z-Enhancer is OFF. If it is on excite or bass boost you cannot adjust bass or treble
Oct 14, 2010 | Clarion DXZ665MP CD Player
How do i set it
i called sony and talked to tech support and they said that there was no loudness setting/the best that could be done was bass/treble/balance/fader/and d-bass(1 2 3) and that was all; in regards to setting the clock/press and hold display button until hour flashes then use volume up or down to set.
Mar 10, 2010 | Sony Car Audio & Video
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Help
Hi Cassie, unless your receiver is a surround reciever, it won't have an actual subwoofer output. The good news is that you can use either a "line out" jack or a "tape out" jack instead, which most receivers do have. These jacks always have the signal, so there are no special settings to remember - simply operate your receiver as usual. Everything comes out of these jacks, not just the bass - but it won't matter since your subwoofer will only reproduce the bass frequencies. The bass information is generally identical in both left and right channels, so either the right or left jack should work fine, and it's okay to leave the other one unconnected. The only bad thing is the line and tape outputs are not affected by the receiver's bass and treble controls, so you'll have to control the bass volume at the subwoofer if it has a control. If you can't control the amount of bass you hear, turn up the volume and reduce the treble which will give the illusion of more bass. I'm assuming you have "powered" subwoofer (has its own built-in amplifier). Good luck!
Jun 22, 2008 | Bose Acoustimass 15 System
Subwoofer playing in stereo sound
i think uyou have to got to stereo mode and turn ion the subwoofer option. i have a h/k thats wart i had to do in evvery mode is designate the s/w. rating please
Jan 24, 2008 | Denon AVR-1907 Receiver
225 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
