Question about Boating
The canoe is split on each end and has a hole in the center on the bottom. I was thinking of doing a "stitch & Glue" on the ends then layering fiberglass over the hole in the bottom, layering fill in layers before applying layers that will cover the hole thus letting it retain its shape. I am no expert in this and need some advise from a professional.
  • 2,100 Answers
What ever you do, you need to grind down the gelcoat if it has any and get down to some fresh glass, wipe clean with acetone and have your pieces ready cut and ready to stick on, Go front to back and do the middle at the same time, this way you won't need to sand in between coats, just keep laying on the cloth, you will need some 9 oz cloth, about 4 inches wide, boat resin, acetone, rubber gloves, Popsicle sticks, measuring cups, hair paint brushes, the cheap ones, paper paint buckets, etc, staple a plastic sheet down to a piece of plywood, lay out your strips and saturate them with resin, lay them on the patch, inside and out, roll flat with a roller sold at fiberglass supply stores, like boat supplies, Let it set up, and then do some final sanding, you should be all set. I would put about 3 or 4 layers on all the holes. Make sure you measure your resin and hardener exact and make sure it is hot out, and dry if you can, no humidity, no cold weather. Hope this helps.
Posted on May 28, 2011
Can I sew on buttons?
Set the zig zag the width of the holes. Do you have a button foot looks kind of like a half moon
Apr 25, 2015 | Bernina Sewing Machines
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
How can I make a buttonhole that's bigger than my buttonhole foot will allow
Measure the button, mark the size of hole you want with a pin at each end. sew 6 full width very close zigzag stitches at one end ending on left side , then sew down to the other end with needle in left position with #2 width stitches, at other end again sew 6 full width zigzag stitches finishing on right side, turn work right around and sew back to other end again with #2 width stitches.
you should now have a rectangle of very close stitches with a very narrow gap between them down the middle. carefully cut between the stitches and you have a button hole.
Feb 25, 2014 | Sewing Machines
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
Leather couch seam tear
Don't work with some glue. You must fix it from interior side. Or you can sew with needle and thread black exterior, but a Chinese work. This solution will take time, the solder did not think so.
Jun 24, 2013 | Furniture
We would like to know if anybody knows how to fix spiderweb cracks and cracks in the outside shell on the bottom of our canoe?
whats it made of?if its fibreglass,you can sand it down[around the cracks]and relay the fibreglass cloth with the special glue,and build it up.follow the repair kits instructions..reasonably cheap to fix
Sep 14, 2010 | Old Town Charles River Canoe -
The hinges on the kitchen cupboard door have fallen off leaving large holes in the contiboard. How can I fix this ? Do I have to drill new holes ?
Simplest, neatest fix for this is to drill the holes larger, then plug them with a piece of dowel glued in with yellow wood glue. Wait overnight for the glue to dry before drilling new small holes in the dowels (same location as the original). The fit of the dowels in the enlarged holes is important. Many cheap dowels are poorly sized, or sized before they are dry - so do a trial fit in wood scraps before you drill the larger holes in your cabinets. Take the scrap of wood with you to try the dowels before you buy them. You should be able to insert the dowel in the hole by hand, but it should not wiggle around. If the holes in the cabinet are into the narrow (3/4 inch) edge of a board and the fit is too tight, you will split the board - especially if the board is particle board. You can mitigate this by clamping the thickness of the board when you insert the dowel, leaving the clamp in place while the glue dries. If the board is already split, then spread the split a little and get some glue into the crack before you insert the dowel. And if you carefully control the depth of the hole you drill (perhaps by putting a piece of tape on the drill bit) and making the dowels just a little bit shorter than the depth of the hole, then you can install the dowel flush so you don't have to trim it off. But for this to be practical you need to be able to cut the dowels squarely and neatly - or sand the end nice and square before you insert it. Wipe off the excess glue before it dries.
Good luck. Thanks for using FixYa.
Apr 01, 2010 | Drills
There is a large split to the bottom and side
I don't have any info on how to fix this, but I do know that wooden canoes can be very heavy, so you may want to look into getting a lighter one, i.e. fiberglass.
Oct 11, 2009 | Boating
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Boating Logo
146 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
