Question about Brother Innov-Is 900 Sewing Machine
The thread from the bobbin is getting caught, not sure on what. it gets completely stuck after two stitches and makes a grinding noise. The stitches aren't any good either, they comeout when we pull the fabric off the machine.
bargainbox
  • 1388 Answers
SOURCE: bobbin tension
This is an issue of your upper thread tension, so take a look at this generic tension solution
If you are in a pickle with your bobbin case, check top tension and bobbin case are free of lint, reset the top tension to 4, and adjust the bobbin tension to suit......some more detail on how to do that, is here
Bargain Box
Posted on Jan 30, 2008
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 26 Answers
SOURCE: Thread bunching up on bottom of fabric
with all the stuff you say I think that you should try what I do clean it with canned air. Then change the needle you may have a burred or bent needle. and when you clean the machine make sure to use a qtip with oil on it and swab the bobbin holder it may have broken needle piece stuck in it. if after that is done it still not working then adjust the tension taking care to note the positions first.make sure you change only one at a time and put it aback if it doesn't fix the problem and try another position. you may need to try the specialneedle for the fabric (stretchy or jean type)
Posted on Mar 08, 2009
bargainbox
  • 1388 Answers
SOURCE: Huge loops on back of fabric!
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
Set Top Tesion to 4 ....then....
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
bargainbox.com.au
Posted on Aug 02, 2009
Singer 7442 won't stitch at all. It picks up the bobbin thread nicely, but after that won't stitch at all. Any suggestions?
Sound like one or the other of the threads is stuck. Completely un- thread your machine and remove the bobbin. See if the needle moves freely with the machine unthreaded. If it does, carefully rethread the machine and reinsert the bobbin, making sure the bobbin thread is feeding the correct direction. Let us know what happens.
Oct 23, 2016 | Singer 7442 Mechanical Sewing Machine
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
I have just purchased an LSS-505 machine and I have not been able to get sewing yet. The bobbin thread tangles after about 3 stitches. I have done all the troubleshooting that I know to do, changed n
YOUR BOBBIN IS TOO BIG, when the upper thread passes over
to create the stitch it catches on the rim of the bobbin. Make sure there is no lint caught under it or in it's cradle.
Oct 14, 2014 | Michley Electronics, Inc Lil Sew & Sew...
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
I have white D'Lite 1750C the bobbin thread is
try these suggestions
change the needle--use needle according fabric being sewed
rethread the machine top & bobbin
clean under needle plate & in bobbin area for lint or threads
make sure the bobbin is not warped or damaged
make sure the bobbin case is not damaged
if none of these suggestions help, then I suggest having the machine checked
to see if there is something wrong with the inside parts
May 31, 2012 | White Sewing Sewing Machines
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
My thread gets all bunches up under the fabric..not from the bobbin thread, from the top thread..do you have any idea what i am doing wrong?
make sure you have the same type of thread in both the top thread and bobbin.
Also make sure your thread tails are clear, by grasping the upper and bobbin threads, making sure they are under the foot when you start. Hold them as you sew the first few stitches so they don't get caught up in the machine.
Sep 25, 2010 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Not creating a complete stitch
The needle may be threaded from the wrong side. Newer models thread from front to back of the machine, older models will thread from right to left, It is usually determined by the positions of the needle eye. rethread the top, if this does not correct the problem thne rethread the bobbin, use the instr manual to make sure it is correct.
Oct 24, 2009 | Sew D'Lite Sewing Machines
Brother Innov-Is 900 Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
