Question about HP PSC 2355 All-In-One InkJet Printer
Blinking on and warning light
Cannot get my printer to even turn on... It will only blink the on light and the warning light but nothing else will work at all. Any similar problems?
  • Anonymous Oct 04, 2008
    i have the same problem
  • 446 Answers
There could be a problem on your adaptor itself, try holding the coonector that runs through your adapter to your printer till the last end and slowly moved the wire if there is any sign of life the re must be a loosed connection inside,
or try to connect to a different wall outlet.
Posted on Aug 16, 2008
  • 876 Answers
Have you checked for a paper jam?
I would do that first then I would disconnect the printer and leave it off for a few minutes then reconnect and see if it will reset itself. let me know what happens.
HP desjet F2180 blinking orange light
pls tell me abt hp compaq d530sff mother board dive how to download ?
May 30, 2009 | HP Ruggedized DC Car Adapter for HP...
Blinking red warning light
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
Printerndoes not respond
I thought my printer died on me, but it turned out it was a simple paper jam. The whole printer just locked up because of a paper jam! All I had to do was open the top compartment, remove the toner and get rid of the paper jam
Jul 25, 2008 | HP LaserJet 1320n Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
On/off button blinking
Did you check your particular models warning lights page? Maybe your head cleaner is full or the printer needs maintenance. Take a look at your printer manual to see what the warning lights signify. Sometimes printers reset if you remove the plug from the back then push the power button and plug it in again while your still pushing the power button. Then you can try turning it back on normally again...
Dec 09, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
