Question about Asko 24 in. D3350 Dishwasher
Hi, well my asko d3350 has run great for 9 years but today the cycle came on, loads water and then it does not run. nothing. The clock continues to run down to zero but no actual washing.there is the click as it is supposed to do something else (like add water) but nothing happens. It also empties just fine water left over when you try to redo the cycle. I have cleared the codes, turned off the machine and back on but same result. any good ideas? thabks in advance!
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
SOURCE: Asko D3350
Code F7 means "The drain is blocked"
I refer to the troubleshooting section :
Posted on Jan 19, 2008
  • 351 Answers
SOURCE: Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Posted on Mar 02, 2008
  • 24 Answers
SOURCE: ASKO D3350 Dishwasher won't work.
possible failure of electronic board expensive to fix. May even be suprresion capacitor. A lot of brands used suppression caps on the ac input to filter out unwanted noise. When these blow they stink and some even arc but one thing is sure they cut the power to the rest of the dwasher may even throw out your power.Make sure it is switched off and unplugged before dismantling it.
Posted on Oct 08, 2008
SOURCE: Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Posted on Oct 09, 2008
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Dec 31, 2010 | Asko Dishwashers
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
Dishwasher won't run cycle and no water is entering machine
This sounds all to familiar. I had this problem once and it was valve that was closed and would not open. The cause was lime in the water that built up over time. This was an unnecessary expense. Is the water in your area generally hard? Once I replaced the valve, it took care of it.
Dec 25, 2008 | Asko 24 in. D3350 Dishwasher
F2 code flashing
Have you tried to reset the dishwasher to clear out the error code? Toreset, you hold down the "Start/Stop" button (or "Wash Program" buttonon units that don't have the "Start/Stop" button) for 3 to 5 seconds.This should clear the code. Try running a cycle to see if the problemreturns. If it does, you can, if you are completely comfortable withyour mechanical abilities, remove the toe kick plate, the access panel,the "T"-shaped kick bracket and the galvanized guard plate to see ifthere is water in the basepan. I would only remove these panels if I was POSITIVELY comfortablewith doing it. * To remove the screws, you'll need a 20 TORXscrewdriver. If water is present in the base pan, vacuum with a wet/dryvacuum or soak up with a towel or sponge. Run a cycle and inspect forleaks. If the problem continues, contact a local service center: Toll-free @ 1-800-898-1879. Hope this helps...
Jun 06, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Oct 28, 2007 | Asko 24 in. D3350 Dishwasher
My Asko D3330 dishwasher won't load water
Since your dishwasher is under warranty you should contact to the appropriate factory service center for repair your problem !!!!!
Aug 28, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3350 Dishwasher Logo
54 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
