Question about ASUS M4A785M Motherboard
Hi the ethernet controller is not working, can't connect to the internet net got this prompt when I try reinstall the lan driver "The Realtek Network controller was not found..If Deep Sleep mode is enabled please plug the cable" can I buy a lan card?
  • ASUS Master
  • 27,725 Answers
You might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
you might have to connect the usb lead to your modem to get a connection then
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
VIA LAN Driver. If you don
Posted on May 28, 2011
Ethernet Controller Error
Since your wireless is working, the missing driver is for your ethernet port. Go to gateway support driver download (link below). Select your computer by following the on screen prompts and download the driver for you LAN port.
http://support.gateway.com/us/en/product/default.aspx?tab=1
Mar 01, 2012 | Gateway NV7921u (890552676248) PC Notebook
Can't connect to internet the internet. My modem is working okay on another pc.Previously I could connect. I'm using GATEWAY NV54 laptop on Windows 7 Home premium
Have you received Windows 7 installed at the time of purchase? If not, check the compatibility with Windows 7. Check your Ethernet adapter with LAN for its proper functioning. Try using latest driver for Ethernet adapter from the laptop manufacturer. If the adapter is OK, restore the system to previous date on which it used to work or reinstall the operating system as a last resort.
sonsunny
Jun 14, 2011 | Microsoft Ethernet MN-120 Network Adapter
I have an emachine W3107 desktop replaced with A13G v3.0 motherboard in 2009. I've had to reinstall windows XP. I can not connect to the internet. (I'm typing this from my laptop, so I have internet...
You are on the right track!
It sounds like you still need to download and install the LAN driver.
When you go to THIS website you will see the third file you can download is the LAN Driver - Nvidia Ethernet Driver.
After you install the driver and restart your computer should detect if you are connected to the internet via LAN cable.
Hope this helps!
Please let me know if this information was helpful!
Kind Regards
Dec 07, 2010 | Computers & Internet
Wireless connection to internet works. But when I take the eMachine 260 notebook computer to another location with only a LAN cable, the LAN connection to internet doesn't work. What's wrong?
hi there, first thing is to check if drivers for your ethernet is installed in your computer. you can go to control panel then system then device manager then look for network adapter. your ethernet device should be present there tand there is no exclamation point in front. if LAN device is not present, or with exclamation point, you may try reisntalling you LAN card drivers to fixed the issue. you drivers must be located at the driverdisk that came with the system.
thanks
Apr 14, 2010 | E-Machines 6809 Notebook
Just reformatted my dell dimension e510, prob connecting to net
Hi there.
Use the Dell tools system software CD to install the LAN (network) drivers, just pop the CD into the drive and install the CD, once it is installed a new window will pop up giving you an option to install drivers and/or utilities, just look for the LAN or network drivers and restart the PC when prompted the LAN drivers will be installed and you will be able to connect to the internet.
Post back if you have anymore problems.
Good luck and thanks for using FixYa!!
May 09, 2009 | Dell Dimension™ E510 PC Desktop
Ethernet controller driver for P4M 915G/PD1
I think it realtek LAN card. You can download the driver from the following link and try.
ftp://ftp.fic.com.tw/motherboard/driver/1stUtilities_v1.27/LAN/
Nov 25, 2008 | FIC P4M-915PD1 Motherboard
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Lan has limited or no connectivity
go start /run and type cmd ,this brings up the command prompt
type cd \ and hit enter
type ipconfig/release
type ipconfig/renew
this should now have renewed your ip address
filally go to control panel internet options
and if your not using dialup remove it if its still showing
go to lan and auto detect settings
you should be ok now
May 05, 2008 | Dell Latitude C640 Notebook
Ethernet Controller
I had to reinstall XP like 6 months ago, on a dimensions 3000. just reinstall the drivers. here i think this is all of the drivers.
just start "Dell Driver Reset Tool.EXE"
and run "Sownd driver for 3000.EXE"
driver for vga "Intel(R) 82865G Graphics Controller.exe"
and the Ethernet driver "Intel PRO100 VE Network Connection.exe"
Click Here for a zip of all the drivers.
Feb 05, 2008 | Dell Dimension 3000 PC Desktop
ASUS M4A785M Motherboard Logo
478 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
