Question about Speed Queen SWT921 Top Load Washer
How I can change the automatic machen from $1 to $3 dollar
I bought my BMW at scrabyard they told the problem is sensor pully and the machenic put the sensor but still not want to start
check that the immobiliser is operational or the key fob battery is good. run the fault codes to check for other faulty sensors.
Dec 25, 2014 | BMW Cars & Trucks
Do rotors wear out before the break pads do? I own a Honda CR-V 2009 and was just told my rotors need machening but I don't need to replace the break pads. Can this be right?
Hi Nancy,
Typically pads need to be changed more than once before rotors needs to be *replaced*. Most shops machine rotors when changing pads to give them a smooth, even surface. Machining removes groves that cut into them as a result of normal wear (or if pads are not replaced promptly). Machining can straighten warped rotors due to excessive heat / quick cooling. These are definitely NOT considered "worn out".
Worn out rotors must be *replaced* if they are too badly damaged, rusted, etc. or if they have been machine so many times that they are too thin to safely brake the car. There are specific guidelines that spell out exactly how thin rotors can be before they must be replaced. Mechanics measure the thickness of the rotor with a micrometer which reveal thicknesses to the 1/1000 of an inch.
I hope this was helpful & good luck!
Nov 20, 2014 | 2009 Honda CR-V
How to take the safty cover off of a husquvarna sewing machene
I suggest getting a service manual that will show the various screws that have to be removed. In general, pull off the hand wheel, remove the screws from the bottom of the machine, and remove the screws from the back side of the machine. You'll need a set of Torx tools (from the local auto store). Also note that the plastic cover pieces snap together and will have to gently pried apart. Don't take off the front cover unless you have to. It's got electrical connections and is much more difficult to reassemble correctly.
Mar 21, 2014 | Husqvarna Viking 1
I haven't cd for downlode the machen
You can download the printer software / driver from the manufacturer so you can install it to your computer.
Nov 22, 2012 | Office Equipment & Supplies
I have a Toad alarm system fitted to my Mitsubishi Pajero and just lately the alarm keeps going off for no apparent reason approx 1 - 2 minutes after locking the car. If I then unlock and relock the car...
may your alrm wwire having problem so just see your car any machenic may be he can attache the wire . and if battery of aalarm is down machenic will change it. then your alarm work smooth
Mar 02, 2011 | Mitsubishi Outlander Cars & Trucks
Slo prosesing in n70
rehot ur phones bluetooth ic if u r a machenic if no then do it from your any mobile machenic friend
Aug 21, 2009 | Nokia N70 Smartphone
Excel formula
Relative cell reference is address of cell , when copied from one cell to another gets changed automatically.
e.g. Put formula in cell c5 as A5+1 when you copy this from c5 to c6 the address of A5 will automatically changed to A6.
Absolute Cell Reference
As above now put formula in cell C5 as $A$5+1 ,now copy this formula from C5 to C6 if you this formula youwill find cell Address of A5 does not changed.
Mixed Cell Reference:
If we put Dollar ($) sign before Alphabetic cell address i.e.$c5 then even if you copy this formula in any cell , coloumn (c)  will remains constant.
Similarly if we put Dollar ($) sign before Numeric cell address i.e.c$5  then you copy this formula in any cell row address of the cell remains same.(5).
Pl elobarate on remaining two points 'Specific order of formulas ' and 'advance formulas,
Sep 15, 2007 | Microsoft Office Standard for PC
Speed Queen SWT921 Top Load Washer Logo
76 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
