Question about Epson 8350 Projector
The temp light and lamp light are red and projector is not hot
SOURCE: Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Posted on Sep 24, 2007
SOURCE: Flashing red status light on NEC VT45 projector
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
Posted on Mar 03, 2008
SOURCE: Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
Posted on Jun 12, 2008
jahting
  • 70 Answers
SOURCE: Blinking red light
replce lamp ballast board of your projector...
Posted on Oct 08, 2009
projdoc
  • 2236 Answers
SOURCE: lamp and temp lights are flashing while in operation
clean out the projector with canned air. the dust is keeping in the heat and the lamp can't cool down. check the fans, too. check the lamp timer. if it's close to 2000 hours, replace the lamp and reset the timer.
Posted on Nov 10, 2009
My optoma758 projector switches of after a few minutes&the lamp light flicker red@1second
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Dec 05, 2016 | Office Equipment & Supplies
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Infocus in104 projetor problem: power off, temp red, lamp green
Most probably failure of the thermistor or thermal fuse that detects the temperature of the lamp housing - so the projector thinks it's hot even when it's cold. Unfortunately it will need a trip to an authorised service centre for repairs
Apr 04, 2014 | InFocus IN104 Projector
After 10 to 15 minuts automatically system display off
"Temp" light is red ,means that the projector is too hot
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 28, 2014 | Dell 1210S Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
A power cut whilst the projector being used, caused power light to blink red, now the projector doesn't turn on
it could be the fan, colorwheel or high temp. remove the lamp and turn it on. do the fans spin? if not, replace the fans. does the colorwheel (colored glass wheel near the lamp) spin? you should be able to see it and hear a high-pitched whir. if not, replace the colorwheel. if the lamp was still hot when it was turned off, you need to let the fans run and cool. then unplug it, plug it back in and try again.
Nov 07, 2009 | InFocus LP70+ Multimedia Projector
Benq Projector MP721 stops illuminating after about 1 minute on. The lights are as follows: Power: Off, Temp: Red, Lamp: Green. Shortly after the projector shuts off. Thoughts?? My assumption is that the...
it might be dusty enough to hold in the heat. it needs a good cleaning. use canned air. if you still have an issue, the fans might be running too slow or the thermister (temp sensor) may be faulty. sometimes if it gets too hot in there, the thermister needs to be replaced, too.
Sep 11, 2009 | BenQ MP610 Multimedia Projector
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Epson 8350 Projector Logo
341 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
