Question about Hitachi 50V500 50 in. HD-Ready LCD Television
60v500 Hi Big Irish...I see that you have helped tons of people, and I am hoping that you might find time to help me!! When I plug in my 60v500, both fans power on, and the bulb lights up also. The screen will "flicker" for just a moment also. When this happens, all of the LEDs on the Power P.W.B. light up, and on the front panel, the LEDs indicate normal boot up sequence. In about 3-5 seconds, both fans, and the bulb power off. When this happens, all of the LEDs on the Power P.W.B. turn off EXCEPT (green) D913...It will stay on until the TV is unplugged. I have already replaced both fans AND the Power P.W.B. board, and the bulb is almost brand new. Oh, and when it shuts off, on the front panel, the TEMP link will blink, but the others stay off. What should I look at now? Thank you...and feel free to email me at [email protected]!!!
  • 927 Answers
Good Day, eger00;
Try this:
First, some clarification related to this Flowchart is necessary. The block which states * PSL #4 pin Voltage sequence is like below? a) high (3s) b) low (3s) c) high (15s) d) low (3s). This indicates seconds in which the ballast is attempting to light the Lamp. The Connector PSL is a very small connector that actually faces down with the ballast is installed. It is also very difficult to access. It's much easier to use the Spark Gap process for determining if the Ballast is attempting to fire up the Lamp. Take a look at the bottom of the flow chart below. If the Spark Gap sparks when trying to turn on the set, it's almost a guarantee that the ballast is working OK and it's the Lamp that's defective. Also, the LEDs on the front of the LCD will flash in sequence Left to right as this process is attempting to light the Lamp. The front LEDs doesn't guarantee that the ballast is functioning correctly, but it does indicate the System Control process for lighting the Lamp is working.
Good Luck, big IRISH.
Posted on Aug 17, 2008
SOURCE:
Ok ok I am trying to find a cooling fan for the bulb but cant find one on line can someone help send me to a site that will have this bulb cooling fan? and how can i tell if the fan is the true issue
Howdy,
The part numbers for the (2) Lamp fans are: UX21521 (upper) and GS00506 (side). You can obtain these from 1-800-448-2244 at
Hitachi America, Ltd. Digital Media Division
900 Hitachi Way
Chula Vista, CA. 91914-3556
BUT, I do not think this is your concern. It is possible but I have not seen a fan on this Model go bad yet. So, give more information so the TV can be trouble shot better.
Godd Luck, Big Irish.
Dec 02, 2009 | Hitachi 60V500 60" Rear Projection...
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Got it...
Good Day, egear00;
Let me do some research, this info was my head. Please recap what the problem is and what all the items you replaced. Okay?
big IRISH.
Aug 20, 2008 | Hitachi 60V500 60" Rear Projection...
Getting close...thanks
egear00; OK, you have voltage, check this:
1. Filters make sure both are clean
2. Check the power supply and check for bad CAP's
3. Check the lamp sensor.
Aug 19, 2008 | Hitachi 60V500 60" Rear Projection...
Television switch does not bring set on immediately...set comes on some time later.surprising everyone.What is the problem?
Good Day, faymirurhead;
Slow to come on can be caused by several things. If you have a DLP or LCD rear projection the LAMP may be getting weak. Also, make sure is plugged into an a/coutlet directly and not a cable/sat. box.
I hope this was helpful, big IRISH.
Aug 16, 2008 | Televison & Video
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
LIGHT ENGINE FOR THE HITACHI 60V500
Good Day,
One the best ways to contact HIT is via the internet; hitachi corp. The light engine is very common problem for this product. Don't ask them to send part to you, work through a local Authorized Service Dealer. Ask them for a concession on the part. They only give concessions 50% of the time. My customers get the part about 98% of the time.(tech at house with estimate).
Jul 10, 2008 | Hitachi 60V500 60" Rear Projection...
Spot on screen
Good Day, And join the club of bad light engines from HIT,
Jul 01, 2008 | Hitachi 60V500 60" Rear Projection...
Repair lighting engine
Jun 11, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 60v500a polarizer linses
Good Day,
May 09, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
144 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
