Question about Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487
Handler 125 suddenly started popping the circuit breaker. I replaced the diodes. When everything was back together, I pulled the trigger and heard a chattering noise from inside the box. Pulled trigger again, and popped the circuit breaker. What gives?
2 Suggested Answers
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
Posted on Aug 20, 2009
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Trigger siwtch spark cause electric short circuits
short in the ignition switch or loose wire at the ignition switch. if trigger switch is the key ignition switch you referring to.
Sep 02, 2012 | Cars & Trucks
Drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
Nov 21, 2011 | Clarke Power Products Clarke 130EN Mig 110...
My welder suddenly stopped feeding wire and gas when i push the trigger. i'm assuming that either there is a problem with the trigger signal or the duty cycle was exceeded. If the duty cycle was...
I found a manual that has a lot of information in it.These welders only have a duty cycle of 30% so that means you can only run them 3 minutes out of 10.They have thermo switches that shut them down before they get to hot.The house breaker needs to be around 50 amps at least I have a 125 buzz box and a wire feed and that's what I use.I would check the circuit breaker in the house to see if its tripped.I turn my mig on the side so that the shavings from the wire pushing wheels don't get pushed into the liner and clog the wire and make it jam.Well hope this helps.Thank You for choosing FixYa.com and good luck!
http://www.hobartwelders.com/service/owners-manuals/
May 15, 2011 | Hobart Handler 210 Wire Feed MIG Welder
My Hobart Handler 120 stopped working during a welding process. Now when I pull the trigger, the 30a 110v circuit breaker trips. The machine can be turned on and the breaker holds (cooling fan in the...
Please don't give me a bad rating for this. Its just a little extra info. you didn't mention that may help you find the problem. Depending on your specific model, there should be 1 or 2 breakers on the unit it self. If there is only 1, it will shut down the entire machine when tripped. If there are 2, the top one is for the whole unit and the lower one is for the wire feeder motor only. There is also a thermal overload that will shut down everything except the cooling fan. Secure the trigger closed and let the fan run for a while to see if it re-starts when cooled. If the depth of the weld was stable before the problem occurred, I would suspect a short in the motor and not the rectifier. That is not a sure bet though. If the transformer does not start when it cools, UNPLUG the welder and short the transformer to ground to be sure the capacitor is discharged. Then isolate the feed motor and transformer and use an OHM meter to test them individually to ground for a short. With a little luck, it will be the feed motor. Please let me know if this helped at all. I am new and still learning how to explain what I am thinking. Thanks for writing us.
Roger
Apr 02, 2011 | Welding Tools
Breaker blow
You may have a short in the trigger leads that is pulling the weld current back through the leads and through the control cable. The short could be causing the breaker to blow. Can you open up the gun handle (disconnect it from the power source first) and check your trigger leads for cuts or nicks. Also check the outer jacket of the cable for cuts which may be deep enough to allow the current carrying copper to touch the embeded switch leads.
Apr 21, 2010 | Hobart Handler 125 Ez
Bad diode?
Could be. Could also be a shorted winding in the transformer. I have seen the aluminum windings burn and melt on some welders.
Over the years of messing with welders I have hardly seen many bad diodes....it is usually something else.
To check the diodes, you will need to disconnect them inside and use an ohm meter. Set your ohm meter on a low resistance setting and check them in both directions. If you check a diode and it is like you touched the meter leads together (dead short) them yep it needs replacement. When you test them you should read more resistance one direction than the other, if it reads like it is an open circuit like you didn't touch the leads, then test on a higher resistance setting, if you never do show a reading (infinite resistance) then it needs replacement.
May 10, 2009 | Welding Tools
Air handler circuit breaker
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Nov 19, 2008 | Gb Electrical 1 30 Amp Ground Fault...
Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487 Logo
97 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
