Question about Black & Decker Garden
I have an older B&D reciprocating saw i use and i need help with changing the blade. It has an allen screw that hold it in but even when i remove it there is still a small pin that holds the blade. I had to use a punch to drive it out in order to take out the blade. is this normal?
  • 2,100 Answers
No, the pin holds the blade in there as a keeper device, The screw just puts the clamp on it. It was probably just stuck, If the pin is gone, driven out or out of the way, try getting it back to hook the blade on. The clamp alone won't hold it. I tried.
Posted on May 28, 2011
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
We have a ryobi rj150v model reciprocating saw (older model) which needs the blade replaced. It had a broken part, which I ordered several years ago. My husband's FINALLY going to replace the blade,...
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Ryobi Saws
I need directions on how to change the baldes on a reciprocating saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
I have a Sears Craftsman reciprocating saw and do not know how to change the blade. Where can you find manuals for these? Model no. 172.171801
Hi there, Your saw is not listed but you can call this number and they may be able to help you.If your saw has rubber where the saw blade fits just push it back on the shaft and insert the blade they can face frontwards or backwards.If its an older model they had a set key tightened with an Allen wrench.Thank You for choosing FixYa.com. P.S. unplug or remove the battery when changing the blade.
Call (800) 252-1698 during these hours of operation:
Monday - Friday: 6:30 AM to 10:30 PM (CT) Saturday: 7 AM to 9:30 PM (CT) Sunday: 7:30 AM to 9:30 PM (CT)
Jun 24, 2011 | Saws
How to change the blade
look at front off saw , where blade is,there is a hex (allen) bolt, screw, or a lever on the side of saw
Apr 06, 2010 | Craftsman 8.0 amp Reciprocating Saw
How do you install the blade in the craftsman recipricating saw model 320
You need a allen wrench to remove the blade and to reinsall it look at the base of the blade and you will see an allen wrench. If there is no allen wrench then you must pull down on the clap assembly to release the blade. If you still can't figure it out here is sears web site where you can get help for it if you need a picuter.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128394&sid=PSx20071217x00001a
Sep 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
I need instructions on removing the front housing so I can replace the Blade Set on my 8.5 amp Professional reciprocating saw Model 172.267700. I have the replacement part, I just don't want to take it...
Hi again Guy, It is easy to overlook the obvious, I do it a lot. There are two allen screws in the rubber boot at the front bottom that need to be removed to release the foot (or shoe), which should slide out the end. Then the whole boot ( forward hand grip) pulls off the end exposing the assembly you need to replace. Good Luck to you, this should Fixya!
Mar 23, 2009 | Craftsman 8.0 amp Reciprocating Saw
Garden Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
